    4 Posts 3 Posters 195 Views 3 Watching
      djcorbetto
      Hi,Im new to using sketchup and I plan to use it to design new parts for my motorbike.
      My current issue is that I have a cylinder and I want to put a hole through it from one side to the other to show where I want to drill a hole in it, But when I put the circle on the side to create a drill hole the circle just sits on the top and not how I thought which would be wrapped around the cylinder, How do I put a hole through it?
      • mitcorbM Offline
        mitcorb
        Hi, dj:
        I see that you have also posted under topic "Wrapping". Please check this post for several replies, and, welcome if you are a new member here.
          d12dozr
          Does this look like what you want to do?
          http://goo.gl/f7ooYh
            d12dozr
            Oh I see you posted here too: http://forums.sketchucation.com/viewtopic.php?f=79&t=38086&view=unread#unread Just one post is enough.
