Volume attribute in DC
I have put the volume attribute in Dynamic Component Attributes Info writing a plugin with the set_attribute method.
The problem is that the volume attribute don't want to update when i modify the solid.
I have try with the EntitiesObserver onElementModified method,but it only works if I modify the solid without editing it.
Does anyone have the solution for updating the volume attribute in Component Attributes Info?
Register LoginAdvertisement
