    Finalizando imagens no kerkythea. help!
    extensions
    4 Posts 2 Posters 569 Views 2 Watching
      cellomagalhaes
      I'm having a big problem,
      I try to render this image, but always get black spots and imperfections on top of the tub. I have tried all rendering modes.
      the bathroom floor is also imperfect.
      I switched the materials too.
      What is it?
      Thanks!
      • FrederikF Offline
        Frederik
        Without the model or a part of it creating this issue, it's almost impossible to answer...
        My best guess is...
        1.) There's intersecting geometry...
        2.) The material isn't made correct...
        Need to see the actual kzx-file to debug...
        May I ask why you post these questions here and not at the Kerkythea Forum...?? 😐
        Cheers
        Kim Frederik
        • FrederikF Offline
          Frederik
          Having a second look at the image...
          Try moving the lights down/away from the ceiling... 5 cm should be enough...
          The lights is definitely intersecting with the geometry/mesh - somewhere... 😉
          Cheers
          Kim Frederik
            cellomagalhaes
            That's right! I moved the lights down and eliminated the problem.
            Thanks! 👍
