Rendering Problems
I am working on a 9,00 SF +/- operation center. I have the entire interior and exterior modeled. The file size is over 100MB. It takes forever to render using Podium V@. Any suqestions.
Break it up into separate pieces (exterior.skp, interior.skp, at least, if not further). At the very least you should be utilizing layers and turning off objects which aren't in the scene you're rendering.
-Brodie
Register LoginAdvertisement
