    [Plugin] Upload model with custom thumbnail — 12.01.2013
    20 Posts 8 Posters 23.6k Views 8 Watching
      Aerilius
      This plugin allows to choose your own thumbnail image for models shared on Trimble 3D Warehouse. It is mostly intended for people who have not yet been able to upload correct thumbnails due to technical issues.
      The plugin gives two options:
      1. to upload a image (up to 400x300 or 500x300) of your choice from the file dialog
      File → Upload model with custom thumbnail → Choose an image file
      2. to keep the exact same thumbnail that the previous version of the model has in 3D Warehouse (this requires wget on your system).
      File → Upload model with custom thumbnail → Keep the current 3D Warehouse thumbnail
      version 2.1
        What a cool plugin, Aerilius! 😄
        http://sketchup.google.com/3dwarehouse/details?mid=92212c6c19acb8b94e9c9efd1560014e
        I guess many people in the Warehouse will hate you though. From now on, no-one can trust that what we see is what we get.
        If I could have a suggestion however... Currently there are two, top-level entries in the Plugin menu for this plugin. Could you arrange them into one main entry and two submenu items? Like many, I also struggle with a too long list of plugins (even that I have disabled many that I do not use ATM).
        • HumpmetwiceH Offline
          Humpmetwice
          My new favorite plugin, I have been looking for a way to upload my models to the warehouse with an image!
          Thanks lots..............Kurt
            Aerilius
            @66searcher:
            I hope you don't take it amiss 😳 .
            It was not meant as a plugin for everyone but only for those people who couldn't use 3d warehouse before (in the other Google Help Forum). It now allows them to have thumbnails of their actual models, because there occured technical problems where all thumbnails were black.
            I agree that I don't like when people have images of something else, but it has always been possible to upload as "kmz" and then choose any image/photo as thumbnail.
            • 66searcher6 Offline
              66searcher
              @aerilius said:
              @66searcher:
              i appreciate you and i understand that your plugin is helpful...thanks. 👍
              and also i hope everyone use it in right way.not in the way that Gaieus show us !
              http://hamidtoliat.deviantart.com/
                I also agree that it should be used with care... However even nowadays some people upload the files with an image or something in front of the camera and when you download it, you realize that what you got is not what you expected from the thumbnail image. Nevertheless the 3D view will always reveal the true model before downloading.
                @Aerilius, could you consider this small FR above?
                (I know I should be able to edit/modify your plugin but I am not sure how - without screwing it up...) 😳
                • P Offline
                  pavelvan
                  Hi there, what is proper size of 3D Warehouse window, please? I tried to uploud several images, but never wass filled whole window...
                    They want max. 800x600 images there (I think). That's a 4:3 aspect ratio (that is certain) image and will be reduced a bit but fill the window vertically. It will never fill the window horizontally though (neither do the images automatically generated by the WH software).
                      Aerilius
                      I uploaded a new version with support for Unicode file names.
                      • sumasterS Offline
                        sumaster
                        HI,
                        download OPTION is not available
                        "Disable browser ad blocking to view images and download attachments"
                        please Help
                        THANKS
                        Thank you,
                        SUmaster
                          Aerilius
                          → http://sketchucation.com/forums/viewtopic.php?f=179&t=49936
                          Adblock makes it impossible to keep SketchUcation's services running.
                          Click Adblock Plus → Deactivate: on sketchucation.com
                          • arcnhanA Offline
                            arcnhan
                            thanks Aerilius 👍
                            • sumasterS Offline
                              sumaster
                              HI,
                              i can not Download Plugin and not see Images . . . . .
                              Please CHK
                              Thank you,
                              SUmaster
                                Aerilius
                                This has not much to do with this plugin. You get better help here:
                                • sumasterS Offline
                                  sumaster
                                  Hi Aerilius,
                                  thanks for reply . . . . .
                                  i try all these things but not work my laptop . . . .
                                  now i will CHK my software . . . . installation problem . . . .
                                  thanks you Aerilius
                                  Thank you,
                                  SUmaster
                                    66searcher
                                    i agree !
                                      stuartmitch
                                      Hi Aurelius,
                                      I am not sure whether I am too late to post to this topic or whether my question has relativity, but one thing that annoys me in SU is the the inability for each file to bear an custom icon of the model rather than simply the SU generic icon. I have so many models that I can not remember them all by name and need unique images for each icon. Currently I use a slow process of taking a screen snapshot of the model then copy and pasting this into the File info.
                                      Can your plugin be adapted to automate the process of adding a custom icon to the SU model files I keep on my machine?
                                      Cheers...>Scotty
                                        Aerilius
                                        this plugin has a very different scope than what you need. File thumbnails work very differently and the approach of this plugin does not offer a solution for file thumbnails. This forum is full of discussions about thumbnails (ie. no thumbnails on Win64bit, small thumbnails on OS X), and many workarounds [1][2][3]. If you need a file to always the same thumbnail of the model from a specific perspective, you can make use of SketchUp's feature in "Model Info" to disable updating the thumbnail on save.
                                          Aerilius
                                          [off:1waa3eoz]%(#BF0000)[This plugin has no use anymore.
                                          This plugin was designed to hook into SketchUp's upload process to the old Google 3D Warehouse. The old warehouse did not generate thumbnails server-side, so this plugin replaced the temporary image file on the user's computer during the upload process. The new Trimble 3D Warehouse generates preview images their servers so that there is no use for this plugin anymore.]
                                          [/off:1waa3eoz]
                                            stuartmitch
                                            @aerilius said:
                                            Many thanks for clarifying that for me. All understood now.
                                            Cheers...>Stuart
