    Exporting of Shadows to Kerkythea
    4 Posts 3 Posters 673 Views 3 Watching
      Ralf_CT
      When exporting from SketchUp to Kerkythea, should one activate Shadows BEFORE exporting or will Kerkythea create its own shadows based on the Time settings one chooses in Kerkythea? Some of my renderings have no shadows, even though the window is facing East at 09h00.
        The problem might be with the window material...
        • tridemT Offline
          tridem
          normally you export exactly the sun position of SU model in kerkythea without doing anything... check in the KT scene if there's the sun activated, if its position is correct, if the model is right placed on the global axes origin... and perhaps post some screenshots in order to understand better your problem
          • tridemT Offline
            tridem
            @ralf_ct said:
            ..the window is facing East at 09h00..
            but in the north pole on december 25th could make the difference... πŸ˜†
