    Kerkythea question
    9 Posts 4 Posters 588 Views 4 Watching
    • dereiD Offline
      derei
      Maybe some of you will say that I should ask this on KT forum, but I haven't an account there and for this simple question I hope that I will got an answer here too.
      My question is if Kerkythea is able to use clip-planes for camera, to clip geometry in front of camera, but that geometry to participate to rendered image.
      thanks.
      DESIGNER AND ARTIST DEREI.UK
      • tridemT Offline
        tridem
        πŸ˜• I'd say no, there's not such a feature...but can you explain better what you mean?
          SketchUpNoobie
          Have you taken a look at the Zorro 2 plugin? You can make the section cut on a backup of your SketchUp model before importing to Kerkythea.
          Is that what you needed or something else?
          SketchUpNoobie: the complete noob in all things SketchUp.
            ...My question is if Kerkythea is able to use clip-planes for camera, to clip geometry in front of camera, but that geometry to participate to rendered image...
            dereeei, I cannot follow this. Hide it but display it? Or only shadow casting should "participate"?
            • dereiD Offline
              derei
              Is like in Maxwell Render... the camera can "see" through walls, but without affecting the geometry. If you have a mirror facing the camera, you will see the actual room in that mirror, not a hole in the wall.
                And the rooms would have real material from inside? (Sorry, I do not know Maxwell).
                All in all, in Kerky you cannot have those kind of faces which have material on one side and another one on the other.
                • tridemT Offline
                  tridem
                  This would be an useful feature for small ambients like bathrooms... in KT you must invent some workaround or postpro corrections 😞
                  • dereiD Offline
                    derei
                    Is not about the material... is really a "clipping plane". Like sections in Sketchup, but you can't see them like that. Well, you see in front of the "photo camera" a blue square that symbolize the plane, but it doesn't interact with geometry.
                    See this page from Maxwell Render Manual.
                      Okay, I see. No, AFAIK there is no such function in Kerky. If you want to remove a wall, you have to remove it in your model prior to exporting.
                      V-ray has some similar function but the solution is different I think; you assign a transparent material on one side and can see through but when inside, you can see the other material applied on that face of the geometry (or something like that).
