    Custom scales in LO
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    4 Posts 2 Posters 8.5k Views 2 Watching
      samyell77
      Would it be possible to add a custom scales field somewhere so you can type the scale you want, rather than having to add / manage them?
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
        samyell77
        Also - is it possible to view the scales list as just ratios (1:4, 1:50) etc instead of in imperial measurements (1":1'), could this be a preference you can turn on or off?
        SU Pro 2016
        PC Windows 10
        16gb RAM
          In your preferences, you can define anything you wish as a "Scale text".
            samyell77
            Thanks Gaieus,
            Just thought it might be handy if there was a way to type it direct into a field in the View window so you dont have to set it in the prefs. I guess I just need to spend a bit of time getting my LO template sorted out with the most commonly used scales.
            Cheers
            SU Pro 2016
            PC Windows 10
            16gb RAM
