    Circle facets
    4 Posts 2 Posters 631 Views 2 Watching
      dmonahan96
      How do I add more facets to an arc after it has been drawn. and not right after. As I am drawing sometimes my circle and arcs reduce the number of facets that make them up and then look blocky and not smooth. Is there a way changing this?
      Drew
        Hi Drew,
        Until you affect your circle/arc with other geometry (like PushPull into a cylinder for instance), you can always select the curve (circle perimeter, arc edge) itself - but only that - and change the segment count in the Entity info box (right click on the circle perimeter > Entity info or select it and go to the Window menu > Entity info...)
        In fact, my entity info box is always open.
          dmonahan96
          what about after you push/pull it?
            You cannot change it any more. It would affect ll connected geometry (and what would happen with the other circle at the other end of the cylinder?)
