    User feedback: looking for alternative to screen notes
    3 Posts 2 Posters 378 Views 2 Watching
    • liquid98L Offline
      liquid98
      I'm writing a plugin that gives feedback about its operations via screen-notes.
      But screen-notes are buggy:
      http://forums.sketchucation.com/viewtopic.php?f=180&t=36940&p=325358&hilit=info+about+aad_note+method#p325358.
      I was thinking about webdialogs, so I'm looking for a simple example on that.
      Or are there any other alternatives?
      Thnx
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
      • Chris FullmerC Offline
        That is a minor bug, unless you plan on your tool being run very often when there is no geometry in the model. But you can easily check for that, and find a way to warn the user that there needs to be geometry in the model, or add a line yourself or something.
        All my Plugins I've written
        • liquid98L Offline
          liquid98
          Hi Chris,
          Thanx for your help !
          Indeed, the problem arises when there is no geometry. The plugin I'm writing gives feedback on the scale-factor that an object is scaled with. When you press the scale-up button the object is scaled up with a factor. Then the scale-factor is presented to the user as a screen-note. The user can scale up as much as he wants to, and the screen-note will refresh accordingly.
          Then, when the 'scale-down at once button' is pressed, the object is scaled down to its original proportions and the screen-note gets deleted.
          But there arises a problem with a scaled up object and the corresponding screennote. In case the object is deleted ,so there is no geometry, the screen-note is still active. And I can find no way to correct this.
          Thnx,
          Liquid
