    Pan Increments
    3 Posts 2 Posters 868 Views 2 Watching
    • B
      bupaje
      When zooming in close to clean up with the eraser, panning with the hand tool takes longer. Rather than zoom in and then zoom out, then drag with the hand, then zoom in again etc it might be nice if you had an option -like in Photoshop- where holding down the shift key, while using the hand tool, increases the distance covered while dragging.
      Hope this is clear.
      Burt
      Stormvisions
        While using the Erase tool
        use the tool "Zoom Window" don't make the trick? πŸ˜‰
        You can put a shortcut to it (actual is CTRL + SHIFT +W ) if you don't want Click on the tools'bar
        When it's released, Tool Erase comes back πŸ˜‰
        "Zoom Extents" can be useful too
        • B
          bupaje
          I will try - thank you.
          Burt
          Stormvisions
