    🤑 SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
    Tent modeling
    7 Posts 5 Posters 3.7k Views 5 Watching
      robert111
      i need tuto to modeling tent like this picture
      i and with any plugin ?
        d12dozr
        Curviloft Look in that first post for instructions...
        http://goo.gl/f7ooYh
          robert111
          thanks but how to make this tent with metal structure
          • numbthumbN Offline
            numbthumb
            That image really doesn´t show much.
            For tubing you can use this: http://forums.sketchucation.com/viewtopic.php?f=180&t=12354&p=88592#p88592
            Tube Along Path and Pipe Along Path will accomplish that also, if that is what you are after.
            Comfortably numb...
              designerstuart
              or soapskinbubble?
              you don't need a plugin for the tubing though - use followme tool
                numbthumb
                Maybe not. But I would definitely recommed using it when it comes to this, for instance:chassis.jpg
                Comfortably numb...
                  mukul.ar
                  this is the best way to go about it... (and if i may add the easiest) all you need to do is make the lines (or curves) along which you want the surface and then simply use this wonderful plugin to create the surface for you.
                  My Works
