    Display Question
    7 Posts 3 Posters 475 Views 3 Watching
      seasdes
      I am having a problem with a model saved as a Sketchup model.
      In each plane of the model there exists light & dark portions. I cannot figure out how to remove the two tone displays.
      Any ideas will be gratefully received.
      Walter
      Using Sketchup Pro 2019
      • mitcorbM Offline
        mitcorb
        This indicates to me that the surfaces on which these shadings occur are not truly coplanar. They are close to planar, but not dead flat.
        It is sort of like stress lines in an object under torsion. If you were to draw a line along the boundary between the light and dark, the shading might become one value, but now, you have an edge where only a virtual one was before. This could become problematic when rendering.
        In order to get rid of this effect, you will probably have to reconstruct these surfaces.
          seasdes
          Thanks so much for your reply. However, not what I wanted to hear. Thanks.
          Walter
            This is also the appearance when you have extreme smoothing (say of very sharp angles) but in your image I cannot see bounding edges that would not be hard edges. Turn on hidden geometry (View menu) to see what's going on.
            Also, sharing the model itself would be better.
              seasdes
              Thanks Gai
              Changing the softening angles fixed this problem.
              Walter
              • mitcorbM Offline
                mitcorb
                Thanks, seasdes:
                You re-taught me something. I am so lazy that I seldom use the soften slidebar. I just use Control+eraser to hide/soften. That's why you didn't get the answer you wanted. 😄
                And thanks, Gaieus. 👍
                  seasdes
                  Hello Guys
                  I found the solution to my problem. The model was imported into Sketchup too small. Windows were only 1.1 mm high. The model displayed Ok when I enlarged it by a factor of 1000. That is, clipping plane and two tone display are now gone.
                  Thaks for your help.
                  Walter
