    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 430.2k Views 172 Watching
      robert111
      thnaks andre51
      i use fur with this plugin but i haven't nice leaf with fur
      can you show your leaf setting with fur plugin plz
        andre51
        Hi Robert
        I use a leaf component that came with the plants from Solo so I cannot share it here but you can find a lot of ivy on 3D Warehouse. Just load the component somewhere in the drawing and select "make from component" in fur plug-in - you'll see your component listed there. Hope this helps!
        Cheers
        • P Offline
          Pierreden
          @Mac Users: Really sorry about the plugin not working. I have absolutely no clue what the issue is, but I will borrow a mac this weekend and see what i can work out πŸ˜‰
          @Andre: Thank you! Those renders looks great. What plugin do you use? Im currently looking at the distribution of leaves, and that lookes great πŸ‘
          I dont know when the next update will be released, but heres a little teaser of whats to come.
          cheers
          http://i.imgur.com/4R7V2.jpg
          • kaluK Offline
            kalu
            Hi Guys:
            I read all the comments and when select the plugin and I create the Ivy there is not setup so where is the setup? Can I change something or just grow and grow and that's it?
            I place an Image of the plugin installed:
            I missing the "Plugins/SketchupIvy/setup.rb" Is an awesome plugin already see the near future.... Thank you for the great design and comments. πŸ‘
            THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
              andre51
              Hi Pierreden
              I use the fur plug in to distribute the leaves.
              Cheers
              • kaluK Offline
                kalu
                Can someone respond my question?...
                Thanks.
                  mukul.ar
                  Have you tried sending a PM to Pierreden...? he is best suited to answer your queries... Be a little patient... πŸ˜„
                  My Works
                    The forums (this topic) is even better as we can all learn from it.
                    Indeed. The plugin is still in an early phase of coding and what we see is just a preliminary "proof of concept". Somewhere Pierre even wrote that he has not made the settings dialogue yet.
                    (I am also eagerly looking forward to the development...)
                    πŸ˜‰
                    • P Offline
                      Pierreden
                      Thanks.
                      Im sorry for my late reply. I have uploaded a new version which includes a gui!
                      @everyone: Realy hope version 0.3 solves some of yout issues. It feels both faster and more stable on my computer, but if/when you experience problems, bugsplats or bugs, please pm me or write here. I will answer you as quick as possible.
                      Also, f you have any suggestions regarding further development i would love to here them! πŸ‘
                      Regards
                      Pierre
                      • soloS Offline
                        solo
                        Cool UI.
                        One issue, if you close it you cannot open it again.
                        http://www.solos-art.com
                        • P Offline
                          Pierreden
                          @solo said:
                          Cool UI.
                          Thanks for your reply... could you elaborate? I cant recreate it on my system... Are you on a mac? Sketchup 8? And how do you close it?
                          Regards
                          • soloS Offline
                            solo
                            Sure.
                            I opened the UI (from plugin menu) I started creating ivy but decided my ball (wanted it to grow over ball) was too big, so I exited by clicking the close X, resized the ball and tried to start Ivy again, it was checked in menu by no matter what I did the UI did not show again.
                            • pugz1983P Offline
                              pugz1983
                              @solo said:
                              Sure.
                              Same here,
                              I do like the way this Ivy plugin is going. Nice interface, and I thank you are on the right track. Simple Ivy can be made, and i did a few testrenders with indigo and the results are nice. But for large walls covering Ivy you have to make several seperaty ivy bushes I think because of bugsplat when going over 150 branches. But thanxs for the hard work so far, Keep it up and this wil be a very welcome plugin πŸ˜„
                              Greetz Pugz
                              • lele_poggiL Offline
                                lele_poggi
                                Great work!!!
                                gsa | Gabriele Sacchi architetto
                                http://www.gs-a.it
                                • esteromxE Offline
                                  esteromx
                                  reported the same problem as Solo, this problem appears only when you try to put leaves on the vine
                                  • OxerO Offline
                                    Oxer
                                    Hi, i work on Mac and Sketchup reads the plugin but when i run the plugin the Ivy parameters window appears and immediately disappears, for this i can't use it.
                                    [http://www.oxervision.blogspot.com/(http://www.oxervision.blogspot.com/)]
                                    • V Offline
                                      vidy
                                      woow.. this getting to be more and more interesting...
                                      thanks pierre..
                                      regards
                                      still so much to learn..
                                      • soloS Offline
                                        solo
                                        This is heading towards being an epic plugin...similar to what 'Fur' achieved IMo.
                                        • P Offline
                                          Pierreden
                                          Thanks for the thumbs up and critics everyone!
                                          I have fixed solo's bug, will upload i fix later today πŸ‘
                                          @oxer: This is not good. I'm really struggling with mac support. Will fix as soon as i can! Any error messages in the console?
                                          Thank you! Really hope its of use. When i get time i will release additional plugins based on the same principles as this one. Have working proof of concepts for Cloth, fur and a simple particle flow system, all which i hope to develop further in the long run.
                                          Peace
                                          Pierre
                                          • PixeroP Offline
                                            Pixero
                                            Any chance of using existing components as leaves (preferable several different simultaneously) as a compliment to the "built in"?
                                            • 6
                                            • 36
                                            • 37
                                            • 4 / 37
