    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 454.4k Views 172 Watching
      chris87
      @tig said:
      @chris87 said:
      Sketchup 8 pro error !!!
      ... and what happens when you click on 'continue' ?
      The sliders/ivyleaf icons depend on that lib...
      That js error is from one of the standard jquery code libraries - it's relating to 'msie'.
      What version of Internet Explorer do you have ?
      Try updating it...
      IE9
        But IE11 is current, although IE9 ought to be πŸ˜• OK
        • KrisidiousK Offline
          Krisidious
          Ok, since we figured out who Gordon is and I saw his posts contributing to the community, I'm going to assume everything in my folder is up for grabs.
          Now don't go installing this unless you know what you're doing. Let Tig, Rich, Oxer and Myself sort them out, clean them up and see how they should fit in. We'll offer them up in a combined pack afterwards.
          Here it is.
          http://www.sketchup-house-plans.com/Ivy-Leaves-Kris.zip
          Here's what it contains.
          By: Kristoff Rand
            Thanks Kris πŸ˜„
            Remember to use a SKP as a custom leaf you must name it 'ivyleaf_XXXXX.skp' and put it in the ..Plugins//LiveIvy/Textures subfolder.
            The 'XXXXX' can be any text you want [e.g. 'Kris'] - I recommend using something logical - although you will see a thumbnail to click on !
            I also recommend that you consider editing the SKPs to 'hide' some outer edges etc, which will improve the appearance of the 'leaves' etc ...
              Krisidious
              Roger that... I did the 1-10 on the old one but Rich came behind and redid them. So I wanted to touch base with all of you first.
              Do you think we should keep the norms and bumps etc? I take it that's for render monkeys.
              By: Kristoff Rand
                chris87
                I installed iE 11
                The same problem occurs !!!
                  driven
                  I see the same javascript error on my mac, but I believe it is harmless...
                  what happens if you click to continue...
                  john
                    chris87
                    john
                    The panel is open but the tool doesn't function correctly
                      Krisidious
                      What exactly happens? give us a rundown of your steps and the results of them.
                      By: Kristoff Rand
                        Have the Ruby Console open as you use it.
                        Any errors ?
                        What doesn't function properly ?
                        Unless you tell us how can we help !
                        Once the dialog opens set the desired parameters, settings, leaf type[s] etc: then left-mouse click near the base of a wall face to start, keep clicking to add more branches, hold Ctrl [Cmd?] and click to add leaves, use Alt [Opt] and click to grow towards the cursor; hold Shift and click to make the ivy...
                          chris87
                          Any errors ?
                          I am French and it is difficult to give technical explanations in English language :
                          The plant doesn't create itself to the click of the mouse.
                          No error in the Ruby console....
                            Krisidious
                            Normally, most people will see a very small pink line, not real geometry, but a placeholder for a line. Do you not see that either?
                            By: Kristoff Rand
                              Can you try a clean reinstall of the tool, to be sure there are no legacy files.
                              Open the Plugins folder and delete the LiveIvy.rb file and the entire LiveIvy subfolder.
                              Now reinstall it from the downloaded RBZ or the SketchUcation PluginStore AutoInstall red-button.
                              Restart SketchUp and try the tool again.
                              What happens ?
                              What is your OS ? PC or MAC ?
                              Are you holding the modifier keys down while clicking ?
                              Are you clicking on a wall face ??
                                chris87
                                What happens ?
                                I reinstalled several times of course cleanly the plugin.
                                At the first clic (without modifiers keys) a very small pink line appears but nothing happens to the others click
                                however before suspecting a bad use....there was a display of a message of mistake of the program...no ?
                                PC OS : Windows 7 32 bits SP3 - and Sketchup 8 Pro.
                                  Please look at your default settings.
                                  These are the shipped set:
                                                  ;nodesize    => 3,
                                                  ;pattern     => 0.8,
                                                  ;probability => 0.97,
                                                  ;radius      => 0.8,
                                                  ;floatlength => 150,
                                                  ;detail      => 4,
                                                  ;spread      => 0
                                              ;leaf     => {
                                                  ;pattern     => 1,
                                                  ;probability => 0.7,
                                                  ;size        => 5
                                              ;gravity  => {
                                                  ;weight => 1,
                                                  ;vector => [0, 0, -1]
                                              ;wind     => {
                                                  ;weight => 0.1
                                              ;random   => {
                                                  ;weight => 0.3
                                              ;adhesion =>{
                                                  ;max_adhesion_distance => 50,
                                                  ;weight                => 0.2
                                              ;legacy   => {
                                                  ;weight => 0.8
                                  Not all ot them will have dialog headings...
                                  Please reset to those which do apply... and try again.
                                  Remember that it might want the inpy value as 0.2 NOT 0,2 !!!
                                    chris87
                                    >                 ;nodesize    => 3,
                                    >                 ;pattern     => 0.8,
                                    >                 ;radius      => 0.8,
                                    >                 ;detail      => 4,
                                    >                 ;spread      => 0
                                    >             ;leaf     => {
                                    >                 ;pattern     => 1,
                                    >                 ;size        => 5
                                    >             ;gravity  => {
                                    >                 ;weight => 1,
                                    >             ;wind     => {
                                    >                 ;weight => 0.1
                                    >             ;random   => {
                                    >                 ;weight => 0.3
                                    >             ;adhesion =>{
                                    >                 ;weight                => 0.2
                                    >             ;legacy   => {
                                    >                 ;weight => 0.8
                                    Thank you TIG, for your help...
                                    But this plugin doesn't function with my configuration...
                                    I uninstalled it.
                                    Thank you again to have looked for the solutions to the problem
                                    This last will be solved maybe at the time of a next update!
                                    Best regards.
                                      Did you try those default settings ?
                                      Remember sizes are always entered in 'inches'...
                                      And the decimal-separator is a '.' NOT a ','
                                      If you get a small red line at the start it suggests it does start to work, but the settings are wrong...
                                        driven
                                        @tig
                                        do you see the javascript errors?
                                        [Error] TypeError; undefined is not an object (evaluating 'a.browser.msie')
                                        	(anonymous function) (jquery.tools.min.js, line 14)
                                        	global code (jquery.tools.min.js, line 14)
                                        [Error] Failed to load resource; The requested URL was not found on this server. (ui-bg_glass_100_f6f6f6_1x400.png, line 0)
                                        [Error] Failed to load resource; The requested URL was not found on this server. (ui-bg_highlight-soft_100_eeeeee_1x100.png, line 0)
                                        [Error] Failed to load resource; The requested URL was not found on this server. (ui-bg_glass_65_ffffff_1x400.png, line 0)
                                        [Error] Failed to load resource; The requested URL was not found on this server. (ui-icons_ef8c08_256x240.png, line 0)
                                        they first may be causing more than a load error on a Windows PC...
                                        john
                                          @driven said:
                                          @tig
                                          john
                                          I have seen reports, but I do not get those errors on my MAC.
                                          The jquery.tools.min.js code is a standard library that should be IE and Safari compatible...
                                          That is why I have previously asked MAC users OS and if they has the latest Safari installed etc...
                                          Any other ideas ?
                                          Look through the millions of www pages... it seems that newer versions of jquery like the one supplied deprecated $.browser, but the jquery 'tools' still expects it [v1.2.5 is included BUT v1.2.6 & ..7-dev is available BUT not readily downloadable yet] !
                                          Some set ups simply absorb the error, others choke.
                                          I'll look at a fix and get you to test it on your MAC...
                                          EDIT: I did get hold of v1.2.6 BUT it broke the dialog's sliders etc, so that's no use...
                                            driven
                                            I only see it with WebInspector, not as a SU error...
                                            The missing pngs, aren't a big issue, but do point to some packaging anomaly...
                                            happy to test as always...
                                            john
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 36
                                            • 37
                                            • 31 / 37
