    [Plugin] Recurve
    68 Posts 24 Posters 45.3k Views 24 Watching
      bogmusic
      Yo Diggsey
      Superb tool - thanks
      I will give more feedback when the work pressure drops a bit 😞
        MartinK
        Great plugin. Thanks. πŸ‘
          leminilab
          I should have thanked you sooner for this great plugin... β˜€
          Now I'm being punished... πŸ‘Ώ
          I use it quite often but it seems not to work anymore... I can't see the plugin upon right clicking or in the System Preferences/Extensions...
          At least not with the 8.0.15158 (nice name for a version by the way... πŸ˜’ )
          I think I could live without Recurving but I really got used to it now... I'm kind of hooked... πŸ˜•
          Thanks a lot wor your plugin anyway! πŸ‘
          • "Live every day as if it were your last and then some day you'll be right."
          • "ThomThom rules!!!"
          • BoxB Offline
            This one doesn't seem to be working fully in 2014. It will recurve edges but it won't select curve and recurve.
            It is one of my favourite tools, I had a shortcut key for it so you could click on any segment and with one keystroke it would find the path and weld it. I know other ways of doing it but they all require a couple of tools. I'm happy if someone can point me to one that works the same way.
            Diggsey doesn't seem to have been around for a while, I hope he does pop up.
              mcpcorey
              Ditto... I get the same thing here, in 2014 the plug in will not select as it did in SU8 and 2013, Hopefully Diggsey will pop up, and make it fully compatible with 2014.
              I will be hating life working without the full functionality of recurve in SU2014
              Corey
              • fredo6F Offline
                fredo6
                In the meantime, you could use Curvizard - Make Curve, if it helps.
                It has an entry in the contextual menu of SU selection and work on multiple contours at once.
                Fredo
                • BoxB Offline
                  Thanks Fredo, yep I know and love your Curvizard, and all you tools. But what I miss in certain circumstances is the ability to click on one segment and hit a key and get the equivalent of Thomthom's select curve and weld all at once. If you can build that into curvizard I'd be a happy man.
                  • Bob JamesB Offline
                    Bob James
                    +1
                    • 4 / 4
