    Deleting a layer
    3 Posts 3 Posters 1.1k Views 3 Watching
    • K Offline
      kiesewetter
      Hallo!
      I tried to delete a layer named "Balkenlayer" with the following code:
      mod = Sketchup.active_model
      layer_array = mod.layers
      layer_array.each{|l|
      	                if l.name == "Balkenlayer"
      	                   l.erase!
      		                puts "Balkenlayer deleted"
      Why isn't it working?
      Thanks for your time.
      Tim
        There's no API method for Layer or Layers to delete a layer like you could do manually.
        Don't think that because a layer is an 'entity' you can use something like entities.erase_entities(layer) - it will either not work or hang Sketchup...
        Find my code solution here http://forums.sketchucation.com/viewtopic.php?p=166985#p166985
        The script layer-delete.rb adds a new Method the Sketchup's Layer Class -
        "layer.delete()" - it deletes that layer from the model and
        entities that used it get the default layer instead...
        However, if used as "layer.delete(true)" then that layer's geometry is deleted too.
        The default layer cannot be deleted, BUT if you use 'true' anything 'on' it WILL be deleted - so use it sensibly !
        πŸ˜’
        • Dan RathbunD Offline
          Dan Rathbun
          The erase!() method is defined in class Sketchup::Drawingelement
          Sketchup::Layer is a subclass of Sketchup::Entity, NOT a subclass of Sketchup::Drawingelement, so it does not inherit a erase!() method.
          You will need to move all entities off of the layer, then use Layers.purge_unused()
          BTW.. Layers is a C++ collection, not a Ruby Array.
          I'm not here much anymore.
