    Question about code on SU-forum
    4 Posts 2 Posters 343 Views 2 Watching
    • liquid98L Offline
      liquid98
      Hello,
      I have a question about adding lines of code to my posts. Most of the times it looks like this:
      Example Code
      all green 🤓
      But some people on the forum post code in a topic-message with the syntax highlighted.
      How does this work?
      Tnanks a lot !
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
        use [`` code=php`` ] instead
        Unfortunately we do not have a ruby syntax highlighter plugin but the php works, too (somewhat).
        Here is Weld.rb as an example:
        <span class="syntaxdefault"></span><span class="syntaxcomment"># Copyright 2004,2005 by Rick Wilson <br /><br /># THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR<br /># IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED<br /># WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.<br /><br /># Name ;          Weld 3.0<br /># Description ;   weld edges into curve ("polyline")<br /># Author ;        RickW<br /># Usage ;         select edges, then run the script (Plugins>Weld)<br />#            Edges will be joined into a curve ("polyline")<br />#            Script will prompt to find faces<br /># Date ;          4.Aug.2004<br /># Type ;        tool<br /># History;<br />#            3.0 (4.Aug.2005) -  Special Anniversary Edition! ;)<br />#                          now welds to existing curves, adds option<br />#                          to find faces<br />#            2.2 (1.Aug.2005) -  used group/explode to fix most problems<br />#                          still won't weld to non-arc curves<br />#            2.1 (27.Jul.2005) - fixed the fix that caused strange non-welding<br />#                          issues.<br />#            2.0 (25.Jul.2005) - fixed bug where unselected edges were welded,<br />#                          now retains existing faces.<br />#            1.2 (12.May.2005) - fixed edge bug that occasionally resulted<br />#                          in strange edge locations and deletions<br />#            1.1 (10.Sep.2004) - allows working in groups/components<br />#            1.0 (4.Aug.2004) - first version<br /><br /></span><span class="syntaxdefault">require </span><span class="syntaxstring">'sketchup.rb'<br /><br /></span><span class="syntaxdefault">def join_edges<br />    model</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model<br />    ents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_entities<br />    sel</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">selection<br />    sl</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />    verts</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">    edges</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">    newVerts</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">    startEdge</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">startVert</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nil<br /><br /></span><span class="syntaxcomment">#CHECK FOR A VALID SELECTION<br /><br />#    if sel.first.curve<br />#        return UI.messagebox("Please select at least 2 non-joined edges") if sel.length == sel.first.curve.count_edges<br />#    end<br /><br />#DELETE NON-EDGES, GET THE VERTICES<br /><br /></span><span class="syntaxdefault">    sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">item</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">item</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if item</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">typename</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"Edge"</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> verts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">vertices</span><span class="syntaxkeyword">)}<br /></span><span class="syntaxdefault">    verts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">flatten</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">    return UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Please select at least 2 edges"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> if edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> 2<br /><br /></span><span class="syntaxcomment">#FIND AN END VERTEX<br /><br /></span><span class="syntaxdefault">    vertsShort</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">    vertsLong</span><span class="syntaxkeyword">=[]<br /></span><span class="syntaxdefault">    verts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">        if vertsLong</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">            vertsShort</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        else<br />            vertsLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">v</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">        end<br />    end<br />    if </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">startVert</span><span class="syntaxkeyword">=(</span><span class="syntaxdefault">vertsLong</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">vertsShort</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">first</span><span class="syntaxkeyword">)==</span><span class="syntaxdefault">nil<br />        startVert</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">vertsLong</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">first<br />        closed</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />        startEdge </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> startVert</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">first<br />    else<br />        closed</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">false<br />        startEdge </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">(</span><span class="syntaxdefault">edges </span><span class="syntaxkeyword">&</span><span class="syntaxdefault"> startVert</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">edges</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">first<br />    end<br />    </span><span class="syntaxcomment">#sel.clear<br /><br /><br />#SORT VERTICES, LIMITING TO THOSE IN THE SELECTION SET<br /><br /></span><span class="syntaxdefault">    if startVert</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">startEdge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start<br />        newVerts</span><span class="syntaxkeyword">=[</span><span class="syntaxdefault">startVert</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">        counter</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">0<br />        while newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> verts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />            edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">                if edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last<br />                    newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                elsif edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last<br />                    newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                end<br />            end<br />            counter</span><span class="syntaxkeyword">+=</span><span class="syntaxdefault">1<br />            if counter </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> verts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />                return nil if UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"There seems to be a problem. Try again?"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> MB_YESNO</span><span class="syntaxkeyword">)!=</span><span class="syntaxdefault">6<br />                newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">                reversed</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />            end<br />        end<br />    else<br />        newVerts</span><span class="syntaxkeyword">=[</span><span class="syntaxdefault">startVert</span><span class="syntaxkeyword">]<br /></span><span class="syntaxdefault">        counter</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">0<br />        while newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length </span><span class="syntaxkeyword"><</span><span class="syntaxdefault"> verts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />            edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each do </span><span class="syntaxkeyword">|</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">|<br /></span><span class="syntaxdefault">                if edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last<br />                    newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                elsif edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">==</span><span class="syntaxdefault">newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">last<br />                    newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">edge</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">end</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">                end<br />            end<br />            counter</span><span class="syntaxkeyword">+=</span><span class="syntaxdefault">1<br />            if counter </span><span class="syntaxkeyword">></span><span class="syntaxdefault"> verts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length<br />                return nil if UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"There seems to be a problem. Try again?"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> MB_YESNO</span><span class="syntaxkeyword">)!=</span><span class="syntaxdefault">6<br />                newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">                reversed</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />            end<br />        end<br />    end<br />    newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">uniq</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">    newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">reverse</span><span class="syntaxkeyword">!</span><span class="syntaxdefault"> if reversed<br /><br /><br /></span><span class="syntaxcomment">#CONVERT VERTICES TO POINT3Ds<br /><br /></span><span class="syntaxdefault">    newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">collect</span><span class="syntaxkeyword">!{|</span><span class="syntaxdefault">x</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> x</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">    if closed<br />        newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">newVerts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">])<br /></span><span class="syntaxdefault">    else<br />        newVerts</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">push</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">newVerts</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">0</span><span class="syntaxkeyword">])</span><span class="syntaxdefault"> if UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Close curve?"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> MB_YESNO</span><span class="syntaxkeyword">)==</span><span class="syntaxdefault">6<br />        closed</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">true<br />    end<br /><br /></span><span class="syntaxcomment">#CREATE THE CURVE<br /><br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start_operation </span><span class="syntaxstring">"weld"<br /></span><span class="syntaxdefault">    edges</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each </span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">item</span><span class="syntaxkeyword">|</span><span class="syntaxdefault"> item</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">explode_curve if item</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">curve and newVerts</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault">item</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">start</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">position</span><span class="syntaxkeyword">)}<br /></span><span class="syntaxdefault">    </span><span class="syntaxcomment">#sel.each {|e| e.erase!}<br /></span><span class="syntaxdefault">    gp1e</span><span class="syntaxkeyword">=(</span><span class="syntaxdefault">gp1</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">ents</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_group</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">entities<br />    curveEdges</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">gp1e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_curve</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">newVerts</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    $gpents</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">gp1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">explode<br />    ents</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">find_faces if closed and ents</span><span class="syntaxkeyword">[-</span><span class="syntaxdefault">1</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">typename</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"Edge"</span><span class="syntaxdefault"> and UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">messagebox</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Find faces for this curve?"</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> MB_YESNO</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> </span><span class="syntaxstring">"Weld Edges Utility"</span><span class="syntaxkeyword">)==</span><span class="syntaxdefault">6<br /></span><span class="syntaxcomment">#    if $gpents.first.typename=="Edge"<br />#        edges=$gpents.first.curve.edges<br />#    elsif $gpents.first.typename=="Curve"<br />#        edges=$gpents.first.edges<br />#    else<br />#        edges=$gpents.last.edges<br />#    end<br />#    model.active_entities.add_curve(newVerts)<br />#    edges.each_index do |i|<br />#        if i>0<br />#            edges[i].reverse! if edges[i].start!=edges[i-1].end<br />##            if edges[i].start!=edges[i-1].end<br />##                sel.clear<br />##                sel.add(edges)<br />##                join_edges<br />##                return<br />##            end<br />#        end<br />#    end<br /></span><span class="syntaxdefault">    model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">commit_operation<br />    sel</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">clear<br />end<br /><br /></span><span class="syntaxcomment">#ALL DONE!<br /><br />#-----------------------------------------------------------------------------<br /></span><span class="syntaxkeyword">if(</span><span class="syntaxdefault"> not file_loaded</span><span class="syntaxkeyword">?(</span><span class="syntaxstring">"weld.rb"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">    add_separator_to_menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Plugins"</span><span class="syntaxkeyword">)<br /></span><span class="syntaxcomment"># BEGIN CHANGES BY organizerEdit.rb<br /></span><span class="syntaxdefault">if $submenu</span><span class="syntaxkeyword">!=</span><span class="syntaxdefault">nil<br />    $submenu</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Weld"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> join_edges </span><span class="syntaxkeyword">}<br />else<br /></span><span class="syntaxdefault">    UI</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">menu</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Plugins"</span><span class="syntaxkeyword">).</span><span class="syntaxdefault">add_item</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"Weld"</span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">{</span><span class="syntaxdefault"> join_edges </span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">end<br /></span><span class="syntaxcomment"># END CHANGES BY organizerEdit.rb<br /></span><span class="syntaxdefault">end<br /></span><span class="syntaxcomment">#-----------------------------------------------------------------------------<br /></span><span class="syntaxdefault">file_loaded</span><span class="syntaxkeyword">(</span><span class="syntaxstring">"weld.rb"</span><span class="syntaxkeyword">)<br /><br /><br /></span><span class="syntaxcomment">#verts=sel.first.curve.vertices<br />#edges=[]<br />#pts=verts.collect{|v| v.position}<br />#0.upto(pts.length-3) {|i| edges.push(ents.add_line(pts[i],pts[i+2]))}<br />#edges.each {|e| e.erase!}<br /></span><span class="syntaxdefault"> </span>
        • liquid98L Offline
          liquid98
          Hi Gaieus,
          Thanx, it can be so simple! I checked your website, nice website!
            This one?
            http://gaieus.hu/
            hehe. Thanks. Nice but first of all, simple! Does not need too much maintenance. Maybe a gallery would spice it up though...
