    Transparency in textures
    extensions
    5 Posts 2 Posters 867 Views 2 Watching
    • P
      paolodb
      In SU7 I used png images to get transparency in textures, so that the visible part looks like an object with shadows etc. Now in SU8 the "invisible" part is visible. I use Kerkythea to render. Can you help me?
      Freedom is not doing what you want, but wanting what you do (Bossuet)
      • GaieusG
        Is this a Kerkythea problem or SU problem (i.e. the clipping does not work in Kerky or the transparency in SU)?
        • P
          paolodb
          I don't know. When I export from SU7 to Kerkythea, it's all OK. When I export from SU8 the same file, with same textures, transparent part is visible i.e. solid, black or white.
          • GaieusG
            But does it look transparent in SU?
            If yes, this question should be asked here:
            http://www.kerkythea.net/phpBB2/viewforum.php?f=10
            What happens when you check the Clip mapping > Texture in the material editor in Kerky? It will use the image transparency then.
            • P
              paolodb
              Thank you for the suggestion, Gaieus. I didn't remeber that I can modify Clip mapping. It's strange that in the file exported from SU7 I have the pic in the field Texture with Threshold 0.5 and in the file exported from SU8 there is no pic. When I put pic, I have to give a lower value for Threshold (0.1) to see correctly rendered image... πŸ˜• Ok, but at least it works... Thanks!
