    Deleting an observer
    3 Posts 3 Posters 455 Views 3 Watching
    • K Offline
      kiesewetter
      Hallo!
      Is it possible to deactivate or delete an observer after the observer has been invoken? Ideally in the observer itself.
      Thanks for your time.
        I think an observer killing itself is a recipe for failure. 😞
        When you start an observer you couldn give it a global reference like $kieserwetter_observer that is not likely to clash with another global variable.
        Then when you apply it to objects you can always attach the same observer [making a new observer each time will be impossible to keep track of].
        Later if you want to remove an observer from an object you now have a handle [$kieserwetter_observer] to it... in any code at all you might run later...
        • Dan RathbunD Offline
          Dan Rathbun
          You should always be running your code within your OWN namespace, so using a global variable is NEVER needed. I use @@ module vars to hold references to observers.
          YES you can write a method within your observer class that can remove itself. I do this sometimes, and it is really just a wrapper for the remove_observer() method.
          This example assumes your using your Observer in a Singleton manner:
          class MySelectionObs < Sketchup;;SelectionObserver
            @@watched = []
            def attach(selection)
              raise(TypeError,"argument is not a Sketchup;;Selection object.") unless selection.class==(Sketchup;;Selection)
              if selection.class==(Sketchup;;Selection) &&
                 (not self.watching?(selection))
                selection.add_observer(self)
                @@watched << selection
            def dettach(selection)
                selection.remover_observer(self)
                @@watched.delete(selection)
            def verify_watchlist()
              unless @@watched.empty?
                @@watched.delete_if {|e| e.class != Sketchup;;Selection }
                @@watched.delete_if {|e| !e.model.valid? }
            def watching()
              verify_watchlist()
              return @@watched.dup
            def watching?(selection)
              verify_watchlist()
              return @@watched.include?(selection)
            ### define your other callback methods ###
          end # class
          ONE BIG EXCEPTION : NEVER dettach (remove) observers within the onQuit() callback of an AppObserver subclass instance !! A BugSplat! will occur.
          I'm not here much anymore.
