    Modeling problem (help appreciated)
    11 Posts 4 Posters 924 Views 4 Watching
      marcell86
      Hello guys,
      I am new both on forum and with SketchUp. Last time I tried to model a violin key attached below:
      http://img848.imageshack.us/img848/1125/unled2r.th.jpg
      I made an outline of that violin key and saved it to DWG file and simply pulled it up but I came to grisp with problem marked on JPG file.
      I guess it's easier way to do that without making an outline and pulling shapes from it but I made it too learn SketchUp.
      It's important for me to do that in this way (if it's even possible) because I am making a 3D logo for my friend and it has similar shapes (something like a ribbon) and all I had it's an outline of those letters.
      I would be really grateful for any kind of help.
      Best regards,
      Marcell
      PS. sorry for my poor language, english it's not my native lanbuage.
        Hi Marcell (and welcome)!
        Could you please, attach the skp file that you already have? (It is hard to see from the picture what the exact problem is...)
          Well, it did not attach, try again, please. (Maybe it's too large?)
            marcell86
            Here You go 😄 :
            I would be love to teach how to this. It will be very helpful in the future since I am working with organic like shapes.
            letter_P.skp
              marcell86
              Any results ? 😄
              • G Offline
                gulcanocali
                Hi marcell86,
                Take a look at this fountain model in the 3D warehouse. It is a 3D G-clef. I think, it does something similar to what you want to do as explained in the skp file you attached.
                Error 404 (Not Found)!!1
                (sketchup.google.com)
                Gulcan Ocali
                Product Manager
                http://www.Tgi3D.com
                  marcell86
                  Hi gulcanocali
                  First of all I would like to thank You for help 😄 it's really helpful. Now when I know what to deal with it I have one more question, how to pull pull such organic shape.
                  I don't want to be so flat.
                  Best regards,
                  Marcell
                  • mitcorbM Offline
                    mitcorb
                    Are you trying to model it like 3d text? Like stroke width and thickness?
                    Perhaps you want to trace over an image to form closed faces and pushpull it? Then if you don't want it to be uniformly planar you use some bending method?
                    Maybe not. This is just what I thought I "heard" you say.
                      marcell86
                      Hi mitcorb,
                      I haven't try the method with 3D text yet. I will give it a try.
                      I used vector image file saved in *.EPS then converted it to dwg file to easily track the form of this logo. I did it because I thought it's the easiest and fastest way plus it looks perfectly close to original image.
                      Now it's difficult to modify already created shapes.
                      Maybe I shall try from sratch and try another method like extruding shape from edges?
                      ~Marcell
                      • mitcorbM Offline
                        mitcorb
                        Well, you can extrude a shape from edges that form a closed face, which is basic to Sketchup. There are also some ruby scripts that will assist in forming what you want.
                        You could insert a .png image or a .jpg image to start, and with basic Sketchup tools you can create the G/ treble Clef figure. You can also, meticulously bend it out of plane with progression of selection and move.
                        Sooner or later, you will probably use plugins to achieve repetitive procedures.
                        • G Offline
                          gulcanocali
                          @marcell86 said:
                          Hi gulcanocali
                          Best regards,
                          Marcell
                          No problem. Glad if I was helpful. For push/pulling such organic shapes, JointPushPull plugin http://forums.sketchucation.com/viewtopic.php?f=323&t=6708&hilit=jointpushpull by Fredo6 would be very useful I think.
                          Gulcan Ocali
                          Product Manager
