    Hopper Dredger "Crane"
    65 Posts 23 Posters 13.7k Views 23 Watching
      @designerstuart said:
      why do boats always have round corners on the upper levels? it must be more difficult to build.... and model!
      Adds strength and reduces injuries to crew on pitching decks. ๐Ÿ˜‰
      • axeonaliasA Offline
        axeonalias
        Thanks, Im no Ship Designer so I wouldnt know,maybe some research is in order ๐Ÿ˜„
        After being asked for a Wireframe render I had to go and find out how those are done properly, Although this one of the ship isnt 100% right, Max seems to get overloaded easily,I had to cheat and make the faces Opacity 90% so that all the Wires would show, Max would randomly show and hide wires all over as it pleases so ill still have to perfect it,but it works for the interior:
        http://farm6.static.flickr.com/5302/5635427901_c31f62488b_b.jpg
        http://farm6.static.flickr.com/5187/5636007092_217fe11e8b_b.jpg
        http://farm6.static.flickr.com/5109/5635427767_71e16f01f4_b.jpg
        http://farm6.static.flickr.com/5147/5636016622_25e47048d5_b.jpg
        https://sketchfab.com/Axeonalias
        • tademaT Offline
          tadema
          Marius, these are something else, just modeled my first car and it puts me even more in awe of your modelling skills, just simple things you put in like those containers on there own are superb.... ๐Ÿ˜ฎ
          Take care John
          • jason_marantoJ Offline
            jason_maranto
            Massively impressive work! โ˜€
              axeonalias
              Thanks Jason & Tadema,I would like to see the car you had modeled,Ive always kept away from cars since I had a bad experience years ago trying to model a golf4 in Maya...
              And heres a Horrible Unbaked shot in game with the Bridge fitted :
              http://farm6.static.flickr.com/5182/5636158434_4dc3053478_b.jpg
              • Gus RG Offline
                Gus R
                Excellent work as always. It's as if though you can almost touch it.
                www.instagram.com/gusrobatto/
                www.facebook.com/gusrobatto
                  axeonalias
                  Thanks Gus R, In Sketchup... you can touch it ๐Ÿ˜„ thats what sets Sketchup apart from the rest!
                  Work progresses inside the bridge,still plenty to do but im having great fun doing it :
                  http://farm6.static.flickr.com/5144/5637780732_33ea232e56_b.jpg
                  http://farm6.static.flickr.com/5103/5637204855_b1b76e7089_b.jpg
                  And here is the start of the Suction Pipe Control Centre (which Im guessing is no longer in use as the whole suction pipe assembly was removed)
                  http://farm6.static.flickr.com/5266/5637780912_fd7606762e_b.jpg
                  Oh and a Question, what are these rubber mats called? :
                  http://farm6.static.flickr.com/5226/5637784030_ea2e0fc0a6_b.jpg
                    Sergio Morera
                    It is absolutely extraordinary
                    • Mike LuceyM Offline
                      Mike Lucey
                      ๐Ÿ˜ฒ
                        bupaje
                        I think those are called anti-fatigue mats but not sure. It could be recycled tire material as those are durable and no slip. I did a quick Google and this mat seems like a possible candidate but didn't spot a big image.
                        http://www2.blackwoods.com.au/infoBANKProduct.aspx?SG=2000165&S=4084709&G=7522034&P=7800030
                        Burt
                        Stormvisions
                          axeonalias
                          Thanks guys ๐Ÿ˜„ Bupaje Im still searching for a usable texture for those...hard to find and I didnt take any
                          Ok whoa this is quite a mission,im kicking myself for not taking enough photos to use for textures when I was on the bridge,there was just so much! Anyway im going to have to phone them tommorow and reschedule another visit onboard and this time im going to go crazy!
                          I came across a interesting few challanges that I would like to share,some textures had ropoes,lines etc overlapping the photo that will be used as texture,so Gimp is my friend with the cloning tool in order to save such textures,and man there where quite a few,so far ive used over 60 custom textures on this project from the photos that I had taken.
                          Here where 2 of those instances : First one was a simple little piece of steel infront of the clock :
                          http://farm6.static.flickr.com/5184/5639087602_c1b39ccb24_z.jpg
                          Using the Clone tool and carefully pulling nearby colours around,this is the result :
                          http://farm6.static.flickr.com/5105/5639087776_482a7ace66_z.jpg
                          Although you can clearly see it on the texture,its barely noticable on the model however a piece of steel would be instantly cirtisised.
                          Heres a bit of a bigger problem :
                          http://farm6.static.flickr.com/5307/5639087508_24bac8d935_b.jpg
                          And this was the only shot of the printer I had...
                          http://farm6.static.flickr.com/5270/5638511051_913fa721d3_b.jpg
                          And here they are applied on the model:
                          http://farm6.static.flickr.com/5229/5639088220_47f0739fb9_b.jpg
                          Although I am not happy with Many of the textures so far, Its a start at least and now I know what I need to do when I get onboard again.
                          http://farm6.static.flickr.com/5308/5639087846_e1f73e02ef_b.jpg
                          http://farm6.static.flickr.com/5310/5639087902_a8803e6c95_b.jpg
                          http://farm6.static.flickr.com/5145/5638511631_fdbdfbf68b_b.jpg
                          http://farm6.static.flickr.com/5262/5639088048_df16daf575_b.jpg
                          http://farm6.static.flickr.com/5228/5638511799_57d8f23c77_b.jpg
                          http://farm6.static.flickr.com/5266/5639088282_14c40f608a_b.jpg
                            axeonalias
                            Well Folks the hardest part is done, exterior is baked,optimised and cleaned up, in game she is getting a good 60fps on full settings with a compliment of 7 1024x1024 textures and 1 512x512 texture for the fine details like signs and writing.
                            http://farm6.static.flickr.com/5057/5641091353_2f86a572be_b.jpg
                            http://farm6.static.flickr.com/5222/5641660112_4e1d975341_b.jpg
                            http://farm6.static.flickr.com/5014/5641660286_9e72703792_b.jpg
                            http://farm6.static.flickr.com/5302/5641660006_86c321aef5_b.jpg
                            • boofredlayB Offline
                              boofredlay
                              Outstanding.
                              • StinkieS Offline
                                Stinkie
                                I couldn't care less about boats, but this thread kicks *ss. Severely enjoying it. ๐Ÿ‘
                                  bupaje
                                  Beautiful work.
                                  Burt
                                  Stormvisions
                                    axeonalias
                                    Thanks Guys! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                    http://farm6.static.flickr.com/5267/5660347829_2e7ea1c4c8_b.jpg
                                    Well after visiting her again yesterday (Thanks to Jerry ,Transnets Dredging ship manager) ,I was fortunate enough to stand and watch her coming in,of course video and photos where taken a plenty ๐Ÿ˜„ ,a few things noted this time,a few details left out from the model (exterior) but hey,some times you have to draw the line and say..enough is enough,more details will just drag down the fps and its tiny stuff anyway ๐Ÿ˜„
                                    My main focus was the interior ,another 300 photos where taken and added to the 200 from before and still I dont feel it was enough,but the bridge will be highly accurate when it is complete ๐Ÿ˜„
                                    Here is the centre Console that I had no info or photos on last time and the main cause for having to reschedule a second visit :
                                    http://farm6.static.flickr.com/5110/5660911866_94b6248c40_b.jpg
                                    http://farm6.static.flickr.com/5109/5660911942_02dbfbd178_b.jpg
                                      designerstuart
                                      excellent to see a true fanatic every step of his crazy path - thanks for sharing this is wonderful stuff. do you apply basic colour to elements (like buttons, console etc) in sketchup, before detailing it with the render software?
                                        axeonalias
                                        Everything is done in Sketchup,only the renders and baking are done in max:
                                          designerstuart
                                          wow! then in a funny way your work is even more amazing! all those special textures must take ages to apply.
                                            bupaje
                                            Wow, amazing.
                                            Maybe in the future we will have live tracking of ships via GPS so we can watch your ship models moving on Google Earth.
                                            Burt
                                            Stormvisions
                                            • 2 / 4
