    Plugin Request: Show Keypress
    5 Posts 3 Posters 565 Views 3 Watching
      bupaje
      I was wondering if it would be possible dynamically update text labels?
      I would like to record some simple Jing tutorials as I learn and thought it would be cool to echo the keys being pressed to the screen - rather than talking through every step.
      Burt
      Stormvisions
      • PixeroP Offline
        Pixero
        Maybe this one by Jim: http://code.google.com/p/jf-code/source/browse/
          For your purpose you need to find a third party application to do that. SketchUp Ruby can't accomplish what you want.
            bupaje
            I downloaded the code and put it in the Plugins directory. Then I saw Key Codes under the tools menu item -so I guess that's it. I opened the Ruby console and if I select Key Codes I see the 'activated' message and if I select any other key I see 'deactivated.' I'm guessing this must be a helper plugin or just some partial code - or I just don't know enough to use it. Thanks.
            Burt
            Stormvisions
              bupaje
              Ah, thanks. I've been looking but no luck. I was poking at autohotkey but I'm pretty new at that as well. I'll keep looking. πŸ˜„
              Burt
              Stormvisions
