    Component definition name
    3 Posts 2 Posters 453 Views 2 Watching
    • C
      Casey
      How to get the definition name from a selected component?
      I tried the code below, assuming only one component selected which is correct. But this returns just the name not the definition name which is set when the component is created.
      model = Sketchup.active_model;
      selection = model.selection
      componentdef = selection[0]
      UI.messagebox(componentdef.name)
      • TIGT
        You are making a reference to an Instance not a Definition.
        An Instance can have a name separate from its Component's name...
        Do it this way
        component_instance = selection[0]
        component_definition = component_instance.definition
        ci_name = component_instance.name
        cd_name = component_definition.name
        ### to be clever count the instances too ;)
        num = component_definition.instances.length.to_s
        UI.messagebox("Component Definition Name = "+cdname+"\nComponent Instance Name = "+ciname+"\nThere are "+num+" Instances.")
        • C
          Casey
          Works great, thanks.
