    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Roads
    4 Posts 2 Posters 1.0k Views 2 Watching
    • V Offline
      VicBStard
      Although I've found a few road plugins that seem to make nice looking roads, they do no seem to really allow a "proper" road geometric design to be created within sketchup.
      I think that is would be cool to lay out a centreline (straight or curved)- with a report on the length. Create a straight line representing the long section (gradients and rollovers or vertical curves). Extrude a standard cross ection along the centreline using the longsection for the height of the final extrusion. It would be nice to input width, superelevation and cut/fill slopes instead of using a standard section, buyt hey, baby steps.
      Has anyone come across something like this or have workflow that'll do this?
      Cheers,
      Vik
      • W Offline
        wyatt
        I've had some luck using Shapebender for this. It won't handle superelevation, but theoretically will handle a single cross-section. One problem with this method that I've not been able to solve is how to handle intersecting cross-streets.
        Vali Architect's Instant Road maybe starts to do more of what you desire (although I think it uses a terrain surface, not a centerline profile to generate the elevations).
        • V Offline
          VicBStard
          Shapebender did exactly what i want to create a cheap and nasty road alignment suitable for driveways/subdivisions.
          Cheers!
          • W Offline
            wyatt
            Great! I'm glad it worked for you.
