    Error upon opening su
    9 Posts 2 Posters 901 Views 2 Watching
      lapx
      "superclass mismatch for class TR_Tapering" where is this error coming from? This occurs on opening. I have recently added and updated plugins.
      • fredo6F Offline
        fredo6
        This comes from FredoScale. I suggest you reinstall the current version (you may have some files missing or not up to date)
        Fredo
          lapx
          Thanks Fredo,
          But I just did update it and the error remains "superclass mismatch for class TR_Tapering".
          I've updated LibFredo6 3.6b ,FredoScale 2.1a and RoundCorner 2.2c - 23 Feb 11.
          Thanks for your quick answer!
            lapx
            Round corner doesn't load up as well. Might this give a clue fredo?
            • fredo6F Offline
              fredo6
              Do you have the plugins loaded, but not functioning, or is nothing loaded?
              The problem with TR_Tapering is related to LibFredo6. For whatever reasons, you seem to have a problem here, also affecting Roundcorner.
              I would suggest that you recheck the files (including the ZLoader___xx.rb and LibFredo6.rb) and the hierachical organization of the folders.
              Fredo
                lapx
                The error still persist. I'm almost certain the folders are correct. I'll post a screen shot of my folders when I get time.
                Thanks,
                  lapx
                  Here's a txt files with my folders and files arrangement. If anybody wnats to know how this was done, I just found this handy program that prints the directory in a txt file. Ruby God's Let me know how I can clean some of this up. I'm sure some of these rubies may be obsolete or redundant.
                  link for program "Printfolders" below:
                  http://www.stratopoint.com/pfolders_download.htm
                  Thanks,
                  Plugins.txt
                  • fredo6F Offline
                    fredo6
                    Thanks,
                    I notice that you have a file Lib6Transform_30.rb in the main SU Plugin directory. This is an old file, and anyway it should not be there. It is the source of the problem with TR_Tapering. Just delete it.
                    Also, you should delete some other files which are wrongly placed:
                    • LibOnSurface.rb
                    • EraserOnSurface.rb
                    • LineOnSurface.rb
                    • OffsetOnSurface.rb
                    • PolygonOnSurface.rb
                    • PolylineOnSurface
                    This should make ToolsOnSurface work again
                    Fredo
                      lapx
                      Thanks Fredo
