    2D Export SKP file
    1 Posts 1 Posters 734 Views 1 Watching
    • A
      ArCAD-UK
      I know probably sounds a little wierd, but while we w a i t ... for layout to handle an average complex model, any chance in Pro under File > Export 2D graphic we could add the skp file format. Layout appears to handle a basic 2D file a lot quicker than a full 3D model when adding dimensions etc and the only workaround I can see at this time is to export to dwg, import back into SU and save as a new skp file.
      Yes I know about the slice function, but it doesn't give a projected image e.g. anything other than intersections with the cut plane are missing.
