    Linear dimensions
    layout
    1 Posts 1 Posters 724 Views 1 Watching
    • arail1A
      arail1
      Sorry if the answer is obvious but I've just started to use Layout and I can't figure out how to make linear dimensions.
      I want dimensions parallel to the XY axis not aligned to points. The dimensions 214" / 101-1/4" / 112-3/4" were done in SketchUp. I want to be able to do that in Layout but all I get is an aligned dimension point to point as the two other dimensions show.
      Thanks for any advice I can get.
