    Please Help
    2 Posts 2 Posters 215 Views 2 Watching
      debarati
      please check if it is possible to generate a cad file in sketchup like shown in the PDF.
      http://www.laserscanning-europe.com/de/system/files/MH_GE_NN_01_R_2D_GROUND_FLOOR_v1.0_110105_lp.pdf
        From SketchUp (Pro), only the geometry can be exported so if you choose that route, you will need to do som post processing work in a cad application.
        Again, with the Pro version, there comes LayOut which would be able to produce most of what I can see there (hatching patterns should be done with images however). A so called "hybrid" output would be the ideal in this case - edges in vector while image files in raster format.
        LayOut 3 can now export to dwg/dxf too (I do not know how those image hatchings would look like though).
