    How to make a toolbar with a dropdown menu
    12 Posts 4 Posters 5.0k Views 4 Watching
    • M
      morci429
      How to make a toolbar with a dropdown menu that has a list “faces_list=[]” that I created of certain faces
      • thomthomT
        You can't create a native toolbar. The closest you get is making a WebDialog.
        I'm doing that with a plugin I'm currently working on: http://forums.sketchucation.com/viewtopic.php?f=323&t=32810 (see video)
        • M
          morci429
          Amazing work.. i like the toolbar"was that a webdialog?" Any examples or walkthroughs how to make a similar one?
          • thomthomT
            Yes it's a WebDialog. It's nothing more than a dropdown <SELECT> element and some Javascript to get the value from it.
            Have you got any HTML/CSS/JS experience?
            • M
              morci429
              Unfortunately not.
              I will try some google searches
              • thomthomT
                Have a look at beginner webdesigner tutorials.
                Then scan the notes and comments in this thread in regard to the WebDialog class: http://forums.sketchucation.com/viewtopic.php?f=180&t=23445
                • Dan RathbunD
                  Dan Rathbun
                  Your other option (perhaps only temporary to get things working for now,) is to use a popup dialog with a dropdown control.
                  def face_picker( facearray, default_face=0 )
                    face_string_array = facearray.collect {|e| e.to_s }
                    title    = ' Face Picker'
                    labels   = [ 'Choose a Face ;  ' ]
                    defaults = [ face_string_array[default_face] ]
                    values   = [ face_string_array.join('|') ]
                    result = UI.inputbox( labels, defaults, values, title )
                    if (result != nil) && (result != false) && (result != [])
                      # result will be an array, 1 member for each control
                      return facearray[ face_string_array.index( result[0] ) ]
                    else
                      return facearray[default_face]
                  end # def method face_picker
                  Ref: UI.inputbox
                  I'm not here much anymore.
                  • M
                    morci429
                    Great help you guys, really thanks.
                    one more thing tho, how do i get rid of the sketchup logo on the top left corner of the webdialog and also the minimize and maximize buttons??
                    • Dan RathbunD
                      Dan Rathbun
                      See ThomThom's posts:
                      base code
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=31213&start=30#p280148
                      additional code to suppress max & min buttons:
                      http://forums.sketchucation.com/viewtopic.php?f=180&t=31213&start=30#p280151
                      These are Windows only.
                      • M
                        morci429
                        where do i find the file "Win32API"
                        It says "Error Loading File win32.rb
                        No such file to load -- Win32API"
                        • Dan RathbunD
                          Dan Rathbun
                          I posted the two .so files that are distro'd with Ruby v1.8.6-p287, which is the version and patchlevel that Sketchup 8.x uses.
                          http://forums.sketchucation.com/download/file.php?id=54170
                          You can put them in any folder that can be found by the $LOAD_PATH array.
                          Most people just put them in their "Plugins" folder.
                          In your code, use a require statement:
                          begin
                            require('Win32API.so')
                          rescue LoadError => e
                            if e.message =~ /No such file to load/i
                              msg = "This plugin requires the Win32API.so file!"
                              msg<< "\n\nThis file cannot be found using the paths\n"
                              msg<< " in the $LOAD_PATH array."
                              UI.messagebox(msg)
                            else
                              raise
                          • G
                            gabino
                            hi guys, situation is the same with sketchup 2014?
                            i want to make a toolbar with organises approx. 50 tools (each tool is simply the link to a dynamic component). A drop-down menu in the toolbar would be I think best solution. Just like the one what appear in "Getting Started" toolbar.
                            I dont want to make the equivalent in webdialogs, it is possible but i think it would be a mess.
                            please, any ideas?
