    Purge Shortcuts
    2 Posts 1 Posters 387 Views 1 Watching
    • P Offline
      pr0bka
      Hello everyone,
      Quick question, any way to be able to "purge" all shortcuts in the shortcut menu. I noticed in all the version of sketchup i have had, whenever i re-imported shortcuts from a saved file - what it did was save shortcuts - ontop of the already existing ones. So for example if r was for rectangle - and i replaced it with say 'w' and then reused 'r' for circle - the rectangle function would still be saved under r and w (both shortcuts) but the circle function wouldn't be copied. So i was thinking to remedy this, first there could be a shortcut to 'purge' all the default shortcuts, and then assign from an external file. Does something like this exist already?
      • P Offline
        pr0bka
        Hey Guys,
        Figured it out, in case anyone else is curious.
        open regedit
        go to this directory
        HKEY_CURRENT_USER\Software\Google\SketchUp8\Settings
        delete everything except Num_shortcuts
        Now, does anyone know how to make the into a .reg file? or perhaps a .bat file ? πŸ˜„
