    Taking a model to particular coordinates
    44 Posts 5 Posters 3.6k Views 5 Watching
      borg.stef
      So I want to import a model and then take it to particular x and y coordinates in sketchup. I had to do this in 2 different programs since the model had to be selected before taken to the coordinates. The programs are shown below:
      machine = "trial.3ds"
      model = Sketchup.active_model
      show_summary = true
      status = model.import machine, show_summary
      obj = Sketchup.active_model.selection[0]
      pt = model.bounds.center.vector_to([x,y,0])
      tr = Geom::Transformation.translation(pt)
      model.transform!(tr)
      Is there a way to link these in 1 program?
        You'd be better posting queries about scripting in one of our specialized forums...
        Also use 'code' formating as it makes code easier to read...
        Anyway here's my ideas/help...
        ### set x and y as needed...
        x=123.4
        y=567.8
        defs=model.definitions.to_a
        model.import(machine, true)
        defn=model.definitions.to_a - defs ### what you just added
        obj = defn.instances[0] ### the placed version
        ###pt = model.bounds.center.vector_to([x,y,0]) ### errr ???
        ### do you really want to do this as this 'center' is not 'constant'
        ### would it be better as a 'movement' from the
        ### original object's origin/SKP's ORIGIN [0,0,0]...
        pt=Geom;;Vector3d.new(x, y, 0)
        tr = Geom;;Transformation.translation(pt)
        obj.transform!(tr)
        Don't you want to transform the object not the model !?
          And you have all the powers to move any topic belonging there, TIG!
          πŸ˜„
            borg.stef
            yes yes that why my mistake in the last line. Thanks I will try this
              πŸ˜„
              I know but hopefully, this is now 'dead' so moving it now seems a waste of time... πŸ˜’
                borg.stef
                Where are the specialized forums?? sorry I'm not very used to this site! THanks
                  @borg.stef said:
                  Where are the specialized forums?? sorry I'm not very used to this site! Thanks
                  Your post has been transferred by the ever vigilant Gaieus... We are now in the Developers' forum which discusses Ruby etc - there is also a Plugins forum for specific tools... There are many forums and sub-forums please browse them and familiarize yourself - post in the one most relevant to your problem...
                    borg.stef
                    Thanks for that.
                    Dear TIG, I tried your code and it's giving me this error
                    Error: #<NoMethodError: undefined method instances' for #<Array:0x7b62f2c>> C:/Program Files/Google/Google SketchUp 8/Plugins/examples/new2.rb:10 (eval):33:in load'
                    (eval):33
                      @borg.stef said:
                      Thanks for that.
                      (eval):33
                      My fault! Here's the corrected code!
                          x=123.4
                          y=567.8
                          defa=model.definitions.to_a - defs ### what you just added
                          defn=defa[0] ####### FIX #######
                          obj.transform!(tr)
                        borg.stef
                        still not taking the model at those coordinates after importion πŸ˜•
                          It adds the imported object at the origin in the SKP [yes?] - this should be equivalent to the origin in the 3ds file.
                          The Vector3d moves the object by the given x and y values.
                          What values are you using for them ?
                          Try perhaps x=0 and y=100.m - that way if the object moves by 100m you'll know it works!
                          Are there any errors in the Ruby Console when you run this ??
                            borg.stef
                            no errors. its just imported in random coordinates and with the move icon pressed....
                              I don't understand you exactly.
                              If you make x=0 and y=0 it should then simply leave the object where it imported ??
                              What 'Move icon' ?
                              As I don't see your whole code can you check that my example code meshes with it as needed.
                              IF you make x=0 and y=100.m doe sit move the imported object 100m in the green axis ??
                                borg.stef
                                I copy and pasted the code that you gave me and I tried x = 0 y = 0 and even x= 0 y = 100.m but it's doing the same in both cases. Importing the model in a random location. I'm so confused.
                                  So am I.
                                  Can you attach your 3ds file to a post or a Private Message [PM] and I'll look at it...
                                    borg.stef
                                    it shows this message: The extension 3ds is not allowed. 😞
                                      borg.stef
                                      it shows this message : The extension 3ds is not allowed.
                                        Don't worry about the example 3ds [but you could 'zip' that type of file]... I've found the problem. 3ds files import but expect you to pick an insertion point - some file type imports don't... I'm thinking how to circumvent this...
                                          borg.stef
                                          Thanks for your time...you know I'm new to ruby I don't know these details...just built programs from what i found on the net..thanks!
                                            borg.stef
                                            i can't seem to make this thing work 😒
                                            • 1 / 3
