    SP ICBM project
    1 Posts 1 Posters 491 Views 1 Watching
      Barack
      Hi again.
      I am currently working on my latest project- a sketchyphysics ICBM. I am not releasing it on 3DWH, but it will be released here in stages. Rather amateur-ish (as far as meshes are concerned, i am a n00b), but will be improved later on. (Hopefully!) Includes:
      Crash damage
      [primitive] Flame effect
      Destroyable (disappearing) second stage
      Anyway, some screenies:
      Liftoff!
      Levelling off
      Engine cutoff.
      Boooooooom!
      What happens when you only tap the launch key.
      TODOS:
      Explosions
      Smoke when the rocket is damaged
      Bomb explosions
      Sounds
      New mesh
      Better second stage damage (With the split scripted field command in the 2nd stage, it lagged too much, so I used the destroy function)
      Better launchpad.
      Guidance/targeting.(Looks grim, I might need help for this part)
      Crappy at the moment, hope to make a new mesh.
      UPDATE:
      Added a new mesh and nose top (a space capsule!).
      The new mesh with the new capsule attachment.
      NOTE: The capsule doesn't have the crash debris function as the warhead does. (It is a MANNED capsule, after all)
      I'm a Sketchup Free user, nothing else. 3DS is way too expensive, and Pro, ditto. What else do you expect?
      UPDATE: I have some blender knowledge, that is why this signature is edited.
