    Question: SketchUp Web Exporter funky in Firefox
    2 Posts 1 Posters 451 Views 1 Watching
    • A
      andreyman3d2k
      I am using the Google SketchUp Web Exporter to create an HTML page of my model. It works great, except one thing. In Firefox, after the first click/drag (which spins the model fine), any subsequent attempt to click/drag the model results in the mouse being 'captured' by the model and not dragging when the mouse button is down, only up -- when it's down I get the ghostbusters sign. This does not happen in either Chrome or IE, so I think it has to do with the way FF is handling the Javascript. Would appreciate any help, as my JS is very weak.
      Thank you in advance for any help!
      Andrey
      Here is the code that the exporter generates:
      <SCRIPT>
      // list of image filenames
      var imageFileNameArray = new Array(
      'Box3DModelv1x6For3DwebmodelmodifiedB_image0.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image1.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image2.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image3.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image4.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image5.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image6.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image7.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image8.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image9.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image10.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image11.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image12.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image13.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image14.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image15.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image16.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image17.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image18.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image19.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image20.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image21.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image22.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image23.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image24.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image25.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image26.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image27.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image28.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image29.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image30.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image31.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image32.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image33.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image34.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image35.jpg',
      'Box3DModelv1x6For3DwebmodelmodifiedB_image35.jpg');
      // list of html image elements
      var sketchUpImageArray = new Array();
      var currentPos = 0;
      var addToPos = 0;
      var imageCount = 0;
      var sketchUpObj = null;
      var mouseXOrig;
      var mouseX = 0;
      var mouseY = 0;
      var mouseIsDown = false;
      var title = null;
      function init() {
      title = document.getElementById('title');
      sketchUpObj = document.getElementById('sketchUpObj');
      imageCount = imageFileNameArray.length;
      // load up the imageArray with the sketchUp images
      //var left = sketchUpObj.offsetLeft + 400;
      //var top = sketchUpObj.offsetTop + 100;
      for (i = 0; i < imageCount; i++) {
      sketchUpImageArray[i] = new Image();
      sketchUpImageArray[i].src = imageFileNameArray[i];
      sketchUpImageArray[i].className = 'sketchUpImage';
      //sketchUpImageArray[i].style.left = left + "px";
      // sketchUpImageArray[i].style.top = top + "px";
      hide(sketchUpImageArray[i]);
      document.getElementById('sketchUpObj').appendChild(sketchUpImageArray[i]);
      //create a transparent sheet over the images so that the mouseevents go it it
      var sheet = document.createElement("DIV");
      document.getElementById('sketchUpObj').appendChild(sheet);
      sheet.id = "sheet";
      //sheet.style.left = left + "px";
      //sheet.style.top = top + "px";
      sheet.onmousemove = handleRotate;
      sheet.onmousedown = handleMouseDown;
      sheet.onmouseup = handleMouseUp;
      sheet.onmouseout = handleMouseUp;
      setOpacity(sheet, 0.0);
      currentPos = imageCount-1
      show(sketchUpImageArray[currentPos]);
      • When the mouse goes down, start rotating the image
      • @param {Event} mousedown event
        function handleMouseDown(e) {
        if (!e) { e = window.event; }
        getMouseXY(e);
        mouseXOrig = mouseX;
        addToPos = 0;
        mouseIsDown = true;
      • When the mouse goes up, stop rotating the image
      • @param {Event} mouseup event
        function handleMouseUp(e) {
        currentPos += addToPos;
      • Divide the width of the html object by the number of images.
      • As the mouse moves over the html object, show the appropriate image
      • giving the illusion that the user is spinning the object.
      • @param {Event} mousemove event
        function handleRotate(e) {
      if (!mouseIsDown) {
      return;
      getMouseXY(e);
      // STEP is how many pixels equals an image swap
      var STEP = 10;
      var width = sketchUpObj.offsetWidth;
      var delta = mouseX - mouseXOrig;
      addToPos = Math.floor(delta/STEP);
      //handle wrap around
      var wrap = (currentPos + addToPos) % imageCount;
      var newPos = (wrap < 0) ? imageCount + wrap : Math.abs(wrap);
      //hide everyone except the image we are over
      for (var i = 0; i < imageCount; i++) {
      show(sketchUpImageArray[newPos]);
      return false;
      • Get the mouse position from the event e
      • @param {Event} e mouse move event
        function getMouseXY(e) {
        if (e.pageX) {
        mouseX = e.pageX;
        mouseY = e.pageY;
        } else {
        mouseX = event.clientX + document.body.scrollLeft;
        mouseY = event.clientY + document.body.scrollTop;
      if (mouseX < 0){mouseX = 0;}
      if (mouseY < 0){mouseY = 0;}
      • Get the left coordinate of the element
        function getLeft(element) {
        var x = 0;
        while (element) {
        x += element.offsetLeft;
        element = element.offsetParent;
      return x;
      function setOpacity(element, opacity) {
      element.style.filter = "alpha(opacity=" + Math.round(opacity*100) + ")";
      element.style.opacity = opacity;
      • Hides the HTML element.
      • @param element HTMLElement the element we hide
        function hide(element) {
        element.style.display = 'none';
      • show the HTML element.
      • @param element HTMLElement the element we want to see.
        function show(element) {
        element.style.display = 'block';
      </SCRIPT>
      • A
        andreyman3d2k
        After an epic journey, I found the answer!
        the line:
        -moz-user-select: none;
        Must be added to the CSS of #sheet
        Andrey
