    Creating a 3D wall from 2Dpoints(line),Width and Height
    2 Posts 2 Posters 443 Views 2 Watching
    • B
      bilianb
      Hi Everyone
      Greetings from Bilgaria
      Can you help me to make a ruby script, that will create a 3d wall from lines with specific Width and Height.
      these are the points
      366.26651026393
      333.719887067018
      285.616120618378
      189.639454957164
      189.639454957164
      285.793731097276
      627.869695716532
      627.869695716532
      and here is the script that i use to draw lines
      0.upto(pts.length-2) {|i|
      line=entities.add_line pts[i],pts[i+1]}
      lets say the Width of the wall is 8.inches
      and height is a 120.feets
      • TIGT
        I assume that you have successfully applied xyz values to these points needed to make these lines; and put then into an array called 'pts'. You could use...
        lines=entities.add_edges(pts)
        where 'lines' is an array of the lines made.
        now to make the wall - I think the easiest in this case is to make a rectangular vertical face, the width [8"/20cm] and height [12'/3.6m] and then use 'followme' on that face with the lines as the path.
        So make the face at the origin....
        face_pts=[[0,0,0],[8,0,0],[8,0,144],[0,0,144]] face=entities.add_face(face_pts)
        Transform the face's vertices so it is perpendicular to the vector of the first line in 'lines'
        vector=pts[0].vector_to(pts[1]) angle=face.normal.angle_between(vector) transformation=Geom::Transformation.rotation(ORIGIN, Z_AXIS, angle) entities.transform_entities(transformation, face.vertices) face.reverse!
        Move the face to the start of the first line in 'lines'
        transformation=Geom::Transformation.translation(ORIGIN.vector_to(pts[0])) entities.transform_entities(transformation, face.vertices)
        Now do the followme
        face.followme(lines)
        Done...
