    Menu, require and .rb files
    5 Posts 4 Posters 501 Views 4 Watching
      bizello
      Hi guys,
      I've read some posts about require and rb files.
      So, I would like to know if is possible you have a menu that each sub item call a script or function inside differents .rb files? How to do this?
      I have a main scritp and inside it there are a lot of function that can become smaller functions in separate files used by mora than one script.
      Example: I have two rb files: file1.rb and file2.rb.
      File1.rb do an action that use a function from file2.rb . But file2.rb can work alone too. So, I want to create a menu with two subitem to choose file1.rb or file2.rb.
      This would be amazing! I could separate my functions and use them in several othes scripts, without copy the code lines.
      Sérgio A.Bizello
        If you set up each script as a module or a class you can call different aspects of the various methods it contains...
        You can pass arguments like MYtool.new(1) or Mytool.new(2) and in the class's def initialize(opt=1) method of Mytool class you have a 'case' test 'opt 1' do this method and 'opt 2' do this other method etc...
        With a module you'll end up with something like the Geom module and you would use it like that - Geom.Point2d.new(...) or Geom.Transformation.scaling(...) etc etc...
          Cleverbeans
          Thankfully Ruby makes this simple, just wrap it all up in a module and you can split it over multiple files. For example...
          File 1
          module MyModule
              def foo(x)
                  puts(x)
          File 2
          module MyModule
              def bar()
                   foo("Hello World!")
          and by Ruby magik the call to bar works since it's in the same namespace.
          • Dan RathbunD Offline
            Dan Rathbun
            We have topic for discussing Ruby Modules:
            [talk] Using Ruby Modules
            and an informational topic:
            [info] Using Ruby Modules
            I'm not here much anymore.
              bizello
              Thanks guys,
              I'll try Ruby modules
              SérgioBizello
              Sérgio A.Bizello
