    Call align view
    4 Posts 2 Posters 413 Views 2 Watching
    • B
      bluetale
      Hello!
      Is it possible to call the "Align View"-method of the context-menu from a ruby script? Or what kind of script do I need to get such a functionality?
      • TIGT
        It's not a standard 'send_action'.
        To do it in code select the face [somehow - either preselected when code runs as model.selection[0], or determined within your code itself, or 'picked' within a tool].
        Then get
        vector=face.normal.reverse center=face.bounds.center
        Make a new camera using face's values to set the camera, change the view to use that and zoom.
        eye=center.clone target=center.offset(vector) up=Z_AXIS new_camera=Sketchup::Camera.new(eye, target, up) view=model.active_view view.camera=new_camera Sketchup.send_action("viewZoomExtents:")
        If you only want to zoom a selection of things you can either zoom to the preselected set or temporarily select them within your code, and then use the send_action "viewZoomToSelection:"
        πŸ€“
        • B
          bluetale
          thx
          But I receive an error if the faces normal is parallel to Z_AXIS.
          I have added the following lines and it seems to work, but is it the correct solution?
          if !vector.parallel?(Z_AXIS) then
              up = Z_AXIS
          else
              up = Y_AXIS
          • TIGT
            @bluetale said:
            thx
            >     up = Z_AXIS
            > else
            >     up = Y_AXIS
            > end
            It's a good trap! πŸ˜„
            PS you don't need the 'then' and perhaps more 'simply' put
            if vector.parallel?(Z_AXIS)
                up = Y_AXIS
            else
                up = Z_AXIS
