    Some Fun withSU
    5 Posts 3 Posters 652 Views 3 Watching
      dolphus
      Just SU and a freebee gif animator
      http://i458.photobucket.com/albums/qq304/dolphus_006/3drings.gif
        Roger
        Did you carve that out of one piece?
        http://www.azcreative.com
          dolphus
          No it is 3 seperate rings rotating about a common centrepoint in 3 axies 90Degrees appart if that makes sence
            I've taken the liberty to extract the individual 'frames' as png files in the attached folder [with my gifxtractor(path_to_gif)].
            You can now use my ImageAnimator tool.
            Simply insert one of these png files as an Image in any SKP.
            Select that Image and use the ImageAnimator tools to attach the folder of png files to it, then set its timing etc... then run the animation...
            As you continue to do other things in your SKP that image will continue to animate, looping through the frames, until you 'stop' it... πŸ€“3drings.zip
              dolphus
              Neat....or the reverse of how i did it ...cleaver without the sweat,,,
