    [Plugin] Estimates (extended)
    50 Posts 23 Posters 56.0k Views 23 Watching
    • Didier BurD Offline
      Didier Bur
      Here is a small extension to one of the example Ruby script that comes with SketchUp:
      Some basic settings added,
      Assign prices to materials and components,
      Output either to dialog boxes or CSV file.
      English and french languages supported, but easily 'translatable'.
      See readme for install instructions.
      attributes_ext.zip
      DB
      • EarthMoverE Offline
        EarthMover
        This is great. Thanks Didier! πŸ‘
        Content Creator at Skapeup
        • sadyoS Offline
          sadyo
          The plugin is not working properly πŸ˜’ , the result of the "compute estimate" is always 0.00, I already following the plugin usage 😐
          perhaps you could provide us the example of how to using this nice plugin.
          I'm using Win7 Home Premium 64bit & SketchUp Pro 8.0.8411
            Didier Bur
            Maybe you didn't assign a cost to the default material and tested the script on "non-painted" faces ?
            DB
            • sadyoS Offline
              sadyo
              [attachment=0:1yjqif92]<!-- ia0 -->1.jpg<!-- ia0 -->[/attachment:1yjqif92]
              But Mr. Didier, I Allready did assign a cost to the default material and didn't tested the script on "non-painted" faces.
              Mmmm... if you don't mind, would you please to give us the screenshot of how you Assign prices to your materials and components, pleeeease... πŸ˜’
                Didier Bur
                Here is a quick screencapture video: choose settings, assign 2 costs for 2 materials, and calculate total estimate by material;
                Hope this helps,
                2.zip
                DB
                • sadyoS Offline
                  sadyo
                  @didier bur said:
                  Hope this helps,
                  Thanks Mr. Didier, now it worked well
                  • mariochaM Offline
                    mariocha
                    Hum... I wonder, considering the folder they are in, will a re-install or update of SU replace those files with the standard non-customized ones ?
                    %(#008000)[Mario C.
                      Didier Bur
                      yes, I think so. Make a backup first πŸ˜‰
                      DB
                      • fionmacoolF Offline
                        fionmacool
                        Hi All, I'm desperately looking for cost plugin. I am hoping this one will work but when I load this on my Mac I get the following message:
                        Error Loading File attributes.rb undefined method `GetString' for nil:NilClass
                        Any idea what this is about? I really appreciate you creating this plugin. I am hoping to show it to others as a great tool for SU.
                        Thanks.
                        Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
                          Didier Bur
                          Did you install the '.strings' files in your resources/en-US folder (as said in the readme.txt) ?
                          DB
                            fionmacool
                            Yes thanks for that. i didnt read the readme file as usual. anyway, having struggled with this problem I now realise that there are no plugins that will provide material quantities for groups or components. (Please correct me if i'm wrong in this.)
                            Thanks for your help and your useful plugin.
                            • Rich O BrienR Online
                              Al Hart's Space Design
                              http://www.renderplus.com/wk/SpaceDesign_w.htm
                              • P Offline
                                Pink
                                How can I add another currencies because I don't use DOLLAR,EURO,SEK.
                                currencies={"Euro"=>"€","Dollar"=>"$","SEK"=>"SEK","BAHT"=>"BAHT"}
                                I save as to replace the attributes.rb , but it cannot be display in the sketchup.
                                  Didier Bur
                                  Go to line 26 and add your currency to the list that appears in the dialog box:
                                  curList=["Euro","Dollar","SEK","BAHT"].join("|")
                                  Regards,
                                  DB
                                  • G Offline
                                    gia_ginanjar
                                    how about change the unit to square meters? because in indonesia we use square meters unit, thanks in advance
                                      Didier Bur
                                      I don't understand the question. No foolish feet/inches unit here in France too 🀣 .
                                      The script uses the unit you set in your model and outputs areas converting internal inches to your current unit. So whatever unit you use, no problem...
                                      DB
                                        rmagoncillo49179
                                        hi i have a question, the estimate cost for component always shows the "susan" word.and i can't get it to work for component costing can you help me on this. thanks.
                                          Susan is the 2D figurine who is inserted into some of the templates
                                          http://www.sketchucation.hu/wp-content/uploads/2010/09/Susan.jpg
                                          Now to get rid of her, delete the figurine in a new, empty file, go to Window > Model info > Statistics and Purge everything. Then save your file as a template under the file menu and set SU to make this your default template (there is a checkbox at the bottom left for it in the save as template dialog)
                                            thaigringo
                                            Great plugin.
                                            How can I change the default currency that loads when I create a new Model. I have added Baht (I am in Thailand) but when I load a new model the default currency is SEK and I would like it to be Baht.
                                            Fred
                                            • 1 / 3
