    Exporting textures
    4 Posts 2 Posters 399 Views 2 Watching
    • C
      cobb89
      is there a way to export native textures of sketchup as a seamless jpg file??
      • GaieusG
        Mat, SU is not a seamless texture generator. If you have seamless textured already in SU and adjust a face that it fully covers it, you can export that and make a texture that is seamless but of course, what would be the reason, since you could do that by simply exporting the texture image (unless I am missing something here completely)
        • C
          cobb89
          i did that with export 2d graphic but the texture doesn't come as seamless...i need to make a bump map of it..
          • GaieusG
            Go to the material browser > In model folder and right click on your texture thumbnail. There will be an item in the context menu to "Export texture image". IFit is a seamlessly tiling material in SU already, you get the original image which you can use as the source image for your bump map.
            (And nowgo and ad your avatar.)
            πŸ˜‰
