    Sandbox tools Q
    2 Posts 2 Posters 291 Views 2 Watching
      tspco
      Is there a way to specify the depth of a stamp. I only needed 24" so I put a grouped box under the tin as a reference, it worked, but is a hassle, is there a better way?
      SU make 2017, /Twilight Render Hobby
      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
        I generally do not care with the exact depth of the stamp tool while stamping. When you are done, you can just select the stamped face and use the move tool to accurately position it to the desired height. Way easier than suffering with the stamp tool (that's only good to make the stamp outline and offset it in the surrounding TIN)
