    Replace components
    5 Posts 2 Posters 742 Views 2 Watching
      liquid98
      I have this ruby script to replace a component with an other:
      ` require 'sketchup'
      module Swapi
      def Swapi.main
      model = Sketchup.active_model
          entities = model.active_entities
          selection = model.selection
      newDef = model.definitions.load("c:\new.skp")
      oldDef = model.definitions['old']
      oldDef.instances.each { |old_inst|
      t = old_inst.transformation
      ents = old_inst.parent.entities
      ents.add_instance(newDef, t)
      old_inst.erase!
        unless file_loaded?( __FILE__ )
          UI.menu("Plugins").add_item("swap") {Swapi.main}
      end # module
      file_loaded( __FILE__ )`
      But it doesn't work, can someone help me out?.
      And an other question: Is it possible to insert a component from a file wich contains several
      different components?
      Thnx
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
        Assuming that you have the 'old' compo etc...
        newDef = model.definitions.load("c;\\new.skp")
        oldDef.instances.each{|old_inst|old_inst.definition=newDef}
        is much easier...
        Also note that you must use \ for a \ in the file path inside "" otherwise 'newDef' is returned as 'nil'.
        In the Ruby Console set model=Sketchup.active_model and then copy paste that one line model.definitions.load("c:\new.skp") and then model.definitions.load("c:\\new.skp") to see what each returns... 🤓
          liquid98
          Thank you TIG
          still learning... Now it works 😄
          Is it also possible to do this:
          newDef = model.definitions.load("c;\\new.skp(componentX)")
          To load 'componentX' from c:\new.skp assuming that new.skp contains several
          components among which there is a component called componentX?
          Or do I have to do something with the model.definitions belonging to new.skp?
          Making a list and choose from there? I really don't have a clue..
          Please help
            @liquid98 said:
            Thank you TIG
            Please help
            The whole 'new.skp' will load with whatever subcomponents it might have.
            If you only want componentX you have to either have split it out by hand earlier and use that, OR import all of 'new.skp' and then manipulate that. For example, after importing new.skp you have a component definition called 'new' and a definition object pointing at it called 'newDef' [as you coded], you can now iterate through the entities inside newDef thus:
            <span class="syntaxdefault"></span><span class="syntaxcomment">###...<br /></span><span class="syntaxdefault">defn</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">nil<br />newDef</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each</span><span class="syntaxkeyword">{|</span><span class="syntaxdefault">e</span><span class="syntaxkeyword">|</span><span class="syntaxdefault">defn</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">e if e</span><span class="syntaxkeyword">.class==</span><span class="syntaxdefault">ComponententInstance and e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">name</span><span class="syntaxkeyword">==</span><span class="syntaxstring">"componentX"</span><span class="syntaxkeyword">}<br /></span><span class="syntaxdefault">if defn<br />  </span><span class="syntaxcomment">### do something with 'componentX' or 'newDef'### e.g.<br /></span><span class="syntaxdefault">  inst</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">add_instance</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">defn</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> Geom</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Transformation</span><span class="syntaxkeyword">.new(</span><span class="syntaxdefault">ORIGIN</span><span class="syntaxkeyword">))<br /></span><span class="syntaxdefault">  xdef</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">inst</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definition<br />  inst</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">erase</span><span class="syntaxkeyword">!<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">### moves xdef into mainstream defs list outside of nested 'new' entities [name will probably adjust too?]<br /></span><span class="syntaxdefault">  </span><span class="syntaxcomment">###...<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#if<br />###...<br /></span><span class="syntaxdefault"> </span>
              liquid98
              Hi Tig,
              I'll do some more study until I get what you suggested and come back
              here 😒
