    Obj export problems???
    3 Posts 2 Posters 1.5k Views 2 Watching
      dydra
      Hello all! I am trying to export some pieces I have modeled with sketchup and edit them with ZBrush. I am using [Plugin] OBJexporter v1.1 20110106 to export from sketchup to zbrush and I am getting these results:
      http://img233.imageshack.us/img233/3971/problemssketchup.jpg
      Some surfaces seem not to be rendering or exporting correctly. I wonder if it has to do with the obj exporter or maybe my hardware not being capable of processing it, but as I can load them correctly with 3DStudioMax I wonder if that is what is happening.
      Thank you for your time,
      Dydra
        In Zbrush
        Load a fake sphere 3D, Make Polymesh 3D
        and you will see a new Menu Import in the Menu Tool Palette! πŸ˜’
        There you can make some regulates, Weld, quad etc...
        Don't forget also Menu Properties /Double for have multi face
        Hope this help πŸ˜„
        But if you have 3D MAx you can also export from 3D max πŸ˜‰
        (with weld edges as options)
          dydra
          I did export from 3DStudioMax and tryed to use the exported file in Unity3D and had the same problem as in ZBrush, but this time the files where exported from 3DMax...
