Kerky mat help please
hello,
do I have to have kerkythea materials in a special sketchup folder in order to be "added or attached"?? I cannot for the life of
me figure this one out. i can use all of my material libraries in kerkythea just fine. when i want to import materials in the su2k plugin i always get the same message. where exactly is sketchup looking for the kerkythea materials??? sorry that i have posted this before but i cannot move forward with this issue. thank you... -
I think you'd be better to post this topic in the http://www.kerkythea.net/joomla/ website.
Have you already tried a test render to KT using KT2SKUP? It determines the path on the first run.
If you do have problems with KT, I can recommend stumping up for Twilight Render - it's very straight forward to use for SKUP users while retaining the power of Kerkythea.
Best of luck!
Register LoginAdvertisement
