    Question: Curve on a curved surface.
    4 Posts 2 Posters 480 Views 2 Watching
    • charly2008C
      charly2008
      Hi to all,
      In this example, I would like to draw a curve between point 1 and point 2. The curve should pass on the pipe surface. Right now I have no idea how to do that.
      I have tried Fredos tools on surface, the Arc tool, but do not understand the function completely. Can someone help please?
      Charly
      Untitled.skp
      • charly2008C
        charly2008
        Problem solved!
        I have to use Line on surface
        Charly
        • C
          Catmando
          Just curious: what are you trying to do there? Create two intersecting pipes?
          • charly2008C
            charly2008
            I have tried different techniques to construct an aseptic T-piece as it is used in pharmaceutical pipelines. This example is done by Fredos Tool on Surfaces and EEbyRails.
