    Face: concave vs convex
    10 Posts 6 Posters 2.1k Views 6 Watching
    • bomastudioB Offline
      bomastudio
      Any method in the API to convert a concave face into a convex one?
      http://dl.dropbox.com/u/18236667/concave_vs_convex.jpg
      If no I suppose to operate as follow:
      for each vertex of my face
      draw lines to the other vertices fo my face
      I get a "web".
      http://dl.dropbox.com/u/18236667/web.png
      Now I need to create a face (for example with the sandbox "from contour").
      http://dl.dropbox.com/u/18236667/sandbox.png
      Then I clean the coplanar face make it my convex face.....
      http://dl.dropbox.com/u/18236667/convex.png
        todd burch
        That's painful.
        Look for a convex hull algorithm.
          I got a 2d convex hull method in my TT_Lib
          Check out this thread: http://forums.sketchucation.com/viewtopic.php?f=180&t=34306&start=15#p302805
            bomastudio
            thomthom thanks a lot for the suggestion!!!!!
            A question: but how many hours you sleep per day? U are an endless source of code!!!!! 😍 😍 😍 😍
              I occasionally sleep... πŸ˜•
                bomastudio
                it's (of course) works. Thanx U... 😍 😍
                Now, with reference to my procedure any ideas how I can replicate with a ruby the "from contour" of the SANDBOX?
                • Chris FullmerC Offline
                  The name of that process is delauney triangulation. You can find the math and process of it on the internet, just do a Google Search. That being said, I tried to make it once myself and never quite understood the math notation, so hopefully you have a little bit of math background.
                  All my Plugins I've written
                    I never understand the math notations either. But often one can find an implementation in another language or pseudo code. The convex hull code I used in TT_Lib was based on pseudo code in a book I found. I have node idea of how the math fully works, but I managed to translate the pseudo code to ruby.
                    • Didier BurD Offline
                      Didier Bur
                      Delaunay in Ruby is here: http://rhin.crai.archi.fr/rld/plugin_details.php?id=292
                      Download the required file 'delaunay2.rb', I used this file (credits to P. Bourke and C. FalΓ©) for my points_cloud_triangulation script.
                      Hope this helps,
                      DB
                      • jason_marantoJ Offline
                        jason_maranto
                        You can also find TIG's update of the Delaunay ruby here -- though I don't think the changes have anything to do with the math:
                        404 Not Found
                        (forums.sketchucation.com)
                        Best,
                        Jason.
