    Set printer setup in SU to landscape default?
    2 Posts 2 Posters 210 Views 2 Watching
      CalypsoArt
      Every time I start a new document the default print is portrait. How can I set SU to be in landscape. I almost never print in Portrait fro SU. I don't want to set it as default in the printer as I do use portrait in other programs. I tried setting in the template but it seems to revert to portrait.
        It is not a SU setting (and definitely not a setting at model level - which means that cannot be set with the template) but indeed a printer setting so you are stuck where you are now and what you already know.
