    130 Free xFrog Plants! (no piracy)
    13 Posts 9 Posters 10.9k Views 9 Watching
    • GaieusG
      http://www.xfrog.com/2011/01/130-free-xfrogplants-now-available/
      • V
        Vicspa
        Nice, thanks for the heads_up. πŸ‘
        • KrisidiousK
          Krisidious
          so which one should we get for Sketchup and does anyone know which ones are best for Vue?
          By: Kristoff Rand
          • GaieusG
            I don't think you should get any of these into SU.
            • KrisidiousK
              Krisidious
              too big and cumberson huh?
              By: Kristoff Rand
              • HieruH
                Hieru
                If you were going to use them in SU, I suppose that the 3ds option might be best. On the few occasions I've used 3ds Xfrog models on SU, I haven't encountered any major problems (except the obvious slowdown).
                www.davidhier.co.uk
                • J
                  jsmith
                  Thanks for the information. These are beautiful models, but the first one I downloaded had a young, medium and adult form of a flowering tree. The total size of the 3 combined was near 350 MG as sketchup models. The only way I can use these is to make elevations and then export them to photoshop for 2D pngs. This will give you a multitude of different looking trees to work with. They will be great for finishing up a rendering in Photoshop, or a 2d tree in sketchup. Included with the downloads are tifs, which can be converted to pngs.
                  • GarethG
                    Gareth
                    a small set of these are available in Twilight....it will grow to almost the full set over the next few weeks
                    • GarethG
                      Gareth
                      they are more manageable than you might think....a little time consuming initially, but well worth the effort..! πŸ‘
                      • A
                        ajohncarter
                        When importing the 3ds files into SU I'm having trouble getting the graphics to look right. For example, with a tree import how to you make the translucent plane that displays the photo graphic of the leaves go away so that just the photo is there? I managed to do it a while back but now I'm rusty... or maybe it was a feature on SU 7?
                        Thanks in advance.
                        Alex
                        • J
                          jumping_jack
                          hello
                          i downloaded one of those free models from the xfrog website, the Rosemary Grevillea: http://xfrog.com/product/OC54.html but i have strange issues during rendering in vray for sketchup. i used the UV Toolkit2 plugin that copies the maps from frontface material to the backface and in vray material menu i checked the transparency form map option, but when i try to render the plant i have a kind of black hole behind it. similar burnt effect i had with overlapping surfaces but it's not the case i guess. anybody of you experienced similar problems before? how can i get rid of it?
                          http://i39.tinypic.com/28wnjbp.jpg
                          it's visible even in the alpha channel:
                          http://i44.tinypic.com/ddcmx1.jpg
                          it appears behind the plant no matter what point of view i choose...
                          • PixeroP
                            Pixero
                            Maybe you should try to up your tracing depth?
                            • J
                              jumping_jack
                              thanks, it wasn't the tracing depth issue, but your post helped me to find out, it was transparency level default setting that was too low, i raised it to 500 and now everything is fine. πŸ˜„
