[Plugin] Triangulate Points
Are you actually selecting the guide-points before running the script ?
Remember that if they are inside a group/component you must edit it, then select them before running the script... -
Hi Im' searching for the related "delaunay3.rb" pluging but I cannot find it, as the link in teh beginnig of teh post is not working. Could you fix that or give us a different link?
Thanks a lot.
Version 2.0 is available from the PluginsStore.
https://sketchucation.com/pluginstore?pln=TIG_points_cloud_triangulation
It fixes issues with delauney3.rb using Constants in away that newer SketchUp versions Ruby chokes on, t also includes some tweaks of the main code - Layers v. Tags etc, and the RBZ is now signed...
Register LoginAdvertisement
