    Pc specification
    extensions
    3 Posts 2 Posters 1.3k Views 2 Watching
      carlodolores
      hi! good day to all, im new here on sketchucation, i just want to ask what is the best pc specification for sketchup using podium renderer, or atleast the proper specification for sketchup and podium, by the im using 7.1 version of sketch up, thanks!
      • mitcorbM Offline
        mitcorb
        From SUPodium Site suplugins.com/help-v2.php:
        "System Requirements for the Mac and for Windows requires SketchUp 7 or 8. Mac version will require OS-X 10.5 or above. The V2 engine is multi-threaded meaning it will take advantage of all your CPU core's. You also need a reasonable amount of RAM to hold 3d scene data. The more RAM you have, the more complex models you can render. However, currently SU Podium V2 is a 32 bit application. Therefore any RAM above 4 gigabytes will not be used."
          carlodolores
          Thank you so much for the info!
